MADRIX 5 Tutorials |
Configuration |
Installation Of The MADRIX Software |
Activate MADRIX License |
Patch Fixtures |
2D Patch With The Matrix Generator For DVI Output |
2D Patch With The Matrix Generator For DMX Output |
3D Patch With The Matrix Generator |
2D Patch With The Patch Editor For DMX Output |
2D Patch With The Patch Editor For DVI Output |
2D Patch With The Patch Editor For Combined Output Of DMX And DVI Fixtures |
3D Patch With The Patch Editor For DMX Output |
Create Fixture Groups |
Working With Background Image |
Merge Patches |
Import A Fixture List |
Highlight Fixtures |
Rotate Fixtures |
Configure Output And Input |
Find USB-Connected DMX Interfaces |
Assign DMX Universes |
Connecting MADRIX 5 With Art-Net Nodes |
Manual Configuration Of An Art-Net Device In MADRIX 5 |
Connecting MADRIX 5 With sACN Nodes Via Multicast |
Connecting MADRIX 5 With A Visualizer Using sACN |
Output To DVI-Based Fixtures |
Configure DVI-Based Fixtures |
Connecting T9 Fixtures |
Remote Control Via DMX-IN |
Remote Control Via Art-Net |
Creating An User-Defined DMX-IN Remote Map |
Remote Control Via MIDI |
Changing A Predefined MIDI-Map |
Advanced Fixture Configuration |
Creating Fixtures With The Fixture Editor |
Working With An Alternative Fixture Library |
Export, Modify And Update A Patched Fixture |
MADRIX Effects |
Basics |
Add And Rename Layers |
Layer Visibility |
Copy, Paste And Insert Of Layers |
Working With Effect Layers |
Layer Mapping |
Layer Mapping With Fixture Groups |
Layer Tiling |
Layer Tiling With Offset |
Layer Mix Modes |
Layer Mix Modes Link |
Layer Mapping And Mix Modes |
Using Parameter Chasers |
Effect Parameter Chaser For Effect Settings |
Effect Parameter Chaser For Map Settings |
Storage Place Parameter Chaser For Opacity Settings |
The Group Control View |
Group Control For Live Control |
Group Control Using Presets |
Group Control Using Group Value Chaser |
Automated Playback |
Timelines |
How To Create Timelines |
Modify Audio Files |
Modify Cue Segments |
Imprint And Copyright |
© 2022 inoage GmbH
