| Now, you can see the Choose Components window.
   In this step, you can choose the components you want to install: ▪ MADRIX: It is always required to install MADRIX. ▪MADRIX KEY: Driver It is also always required to install the MADRIX KEY Driver ▪MADRIX Interface Driver: It is also always required to install the MADRIX Interface Driver. It includes the drivers for MADRIX USBone, MADRIX NEO, MADRIX PLEXUS and MADRIX LUNA interfaces. ▪MADRIX KEY Firmware: Installs the latest MADRIX KEY Firmware. ▪Desktop shortcut: Create a shortcut to the MADRIX software on the Windows Desktop. ▪Quick launch shortcut: Creates a shortcut to the MADRIX software in the Windows toolbar. ▪Examples: Installs some Setup examples, including effects, scripts, and color tables for MADRIX. ▪Interface Driver: Choose this option if want use MADRIX software with a supported third-party DMX interfaces. You don't need this option if you want to use the MADRIX software only with MADRIX interfaces or you use MADRIX only with DVI output.  ▪WinPcap Driver: Choose this option if you want to control the EuroLite T9 (e.g., LSD screens) or 5A or CoulorSmart Link.     |
