3D Patch With The Matrix Generator
This tutorial shows you how to create a patch for a 3D matrix of DMX fixtures.
Date: 10/2018
MADRIX Version: 5.0 (Created with)
We have to create a patch for a 3D matrix of single pixel RGB fixtures. In this project we have 20 fixtures in X, 16 in Y and 20 in Z installed.
The space between the fixtures in Y is 1 pixel.
Regarding the DMX address assignment the fixtures are addressed column by column beginning with the front top left fixture z-layer wise and starts in DMX Universe 1 with DMX Channel number 1.
In MADRIX, please go to Preferences > Matrix Generator .
[Keyboard shortcut F2]
The Matrix Generator opens with the default settings.
The full explanation about all functions of the Matrix Generator you will find in the MADRIX 5 manual chapter: »Using The Software > Patching > Matrix Generator
In the Matrix Generator we have to change the settings to get the required matrix.
We don't need to change the Protocol and the Product if we start the Matrix Generator after a restart of MADRIX
oThe Protocol must be DMX.
oWe are using the Product: !generic RGB Light 1 pixel
The settings in the Placement section:
oThe Count X has to be set to 20, the Count Y has to be set to 16 and the Count Z must be 20
oThe offset for Y have to be set to 1
In the Addressing section we need to do the following changes:
oAccording to the task the Start Corner should be Top Left
oThe Main Orientation have to be changed to Vertical
oAnd the Z-Order will be set to the default value Front To Back
Now we click OK.
[Keyboard shortcut Enter]
After the Matrix Generator was closed MADRIX creates the new matrix with the size of 20 x 31 x  20.
If you need help to change the MADRIX 5 Preview from 2D to 3D presentation mode, please have a look at the chapter »User Interface [GUI] > 3 Previews of the MADRIX 5 Help and Manual.
Congratulations! You have successfully learned how to create a 3D patch with the Matrix Generator.
