2D Patch With The Matrix Generator For DVI Output
In this tutorial we will create an easy 2D patch with the help of the Matrix Generator for DVI output.
Date: 10/2018
MADRIX Version: 5.0 (Created with)
We have to create a patch for a DVI output. The resolution of the screen is 160 pixels in X and 90 pixels in Y.
In MADRIX please go to Preferences > Matrix Generator .
[Keyboard shortcut F2]
The Matrix Generator opens with the default settings.
The full explanation about all functions of the Matrix Generator you will find in the MADRIX 5 manual chapter: »Using The Software > Patching > Matrix Generator
Now we have to change the settings according to our task, to patch a DVI resolution of 160 x 90 pixels.
The Protocol must be changed to DVI.
In this example we create a patch with the Product: !generic RGB Light 1 pixel
The Count X will be set to 160, the Count Y will be set to 90 and the Count Z we don't change and leave it at 1
After we change this setting we click OK
[Keyboard shortcut Enter]
After the Matrix Generator was closed MADRIX creates the new matrix of 160 x 90 pixels immediately.
Congratulations! You have successfully learned how to create a 2D patch for DVI output with the help of the Matrix Generator.
