File Types
<< Click To Display Table Of Contents >> You Are Here: Using The Software > File Types |
You will come across several file types, while working with the MADRIX 5 Software. This chapter explains which file type belongs to which function or which part of the software.
*.msz *.msx |
MADRIX 5 Setup MADRIX 5 Setup Uncompressed Your whole show will be saved. It stores relevant data in one single file; including but not limited to Patch, effects, settings, Cue Lists, Timelines, etc. »MADRIX 5 Setup [New / Open] |
*.msz.msbackup |
Backup of a MADRIX 5 Setup Stores MADRIX 5 Setups automatically as backup files as set up in the file recovery options of the software. »General |
*.mpz *.mpx |
MADRIX 5 Patch MADRIX 5 Patch Uncompressed Stores your Patch. »Patch Editor |
*.mflx |
MADRIX 5 Fixture Library Stores the whole Fixture Library. »MADRIX 5 Fixture Editor |
*.mfxx |
MADRIX 5 Fixture Stores one single fixture. »MADRIX 5 Fixture Editor |
*.mstz *.mstx |
MADRIX 5 Storage MADRIX 5 Storage Uncompressed Stores a complete Storage including all of its Storage Places [i.e., effects]. »Storages |
*.mspz *.mspx |
MADRIX 5 Storage Place MADRIX 5 Storage Place Uncompressed Stores one single Storage Place, and thereby one effect you created. »Storage Places [256 x 256] |
*.mdmxx |
MADRIX 5 DMX Device Settings Stores all relevant settings for your [connected] DMX devices. »OUTPUT Settings |
*.mdvix |
MADRIX 5 DVI Device Settings Stores all relevant settings for your [connected] DVI devices. »OUTPUT Settings |
*.mmrx |
MADRIX 5 MIDI Remote Configuration Stores a MIDI Remote Configuration [MIDI map] for a MIDI controller for the MIDI Remote Editor. »MIDI-IN Configuration |
*.mdrx |
MADRIX 5 DMX Remote Configuration Stores a DMX Remote Configuration for DMX-IN for the DMX-IN Remote Editor. »DMX-IN / Art-Net Remote / sACN Input |
*.mrec |
MADRIX 5 Record Stores recorded effects. »Recording |
*.dxd |
MADRIX 5 DMX Data Stores DMX data for the MADRIX PLEXUS hardware interface. »Recording |
*.mclx |
MADRIX 5 Cue List Stores a Cue List and its entries as well as settings. »Cue Lists |
*.csv |
Comma-Separated Values A file format that can be used for the Cue List or the Fixture List Import of the Patch Editor. »Cue Lists / »Patch Editor |
*.mgcz *.mgcx |
MADRIX 5 Group Control MADRIX 5 Group Control Uncompressed Stores the Group Control including fade-in time, Group Presets, and current values. »Fixture Groups |
*.mtlx |
MADRIX 5 Timeline Stores a Timeline and its segments as well as settings. »Timeline Editor |
*.mscx |
MADRIX 5 Schedule Stores a Schedule including all of its triggers and actions. »Scheduling |
*.mitz *.mitx |
MADRIX 5 Image Table MADRIX 5 Image Table Uncompressed Stores an Image Table for the SCE Image effect. »SCE Image |
*.mctx |
MADRIX 5 Color Table Stores color information [Color Table, Gradient, M2L Color Table, etc.] for various MADRIX Effects. »[Global] Colors And Intensity |
*.mckx |
MADRIX 5 Color Kit Stores the entire setup of Global Color Lists and Global Colors. »[Global] Colors And Intensity |
*.mstrtx |
MADRIX 5 String Table Stores a String Table including its strings and characters for the SCE Counter effect. »SCE Counter |
*.mshtx |
MADRIX 5 Shape Table Stores a Shape Table for various MADRIX Effects. »Using Shapes [Shape Table] [Shape Table] |
*.mepcz *.mepcx |
MADRIX 5 Effect Parameter Chaser MADRIX 5 Effect Parameter Chaser Uncompressed Stores an Effect Parameter Chaser including its Step list for a Layer. »Chaser |
*.msppcz *.msppcx |
MADRIX 5 Storage Place Parameter Chaser MADRIX 5 Storage Place Parameter Chaser Uncompressed Stores an Effect Parameter Chaser including its Step list for a Layer. »Chaser |
*.mgvcz *.mgvcx |
MADRIX 5 Group Value Chaser MADRIX 5 Group Value Chaser Uncompressed Stores an Group Value Chaser including its Step list for the Group Control. »Fixture Groups [Group Control] |
*.mmapx |
MADRIX 5 Map Settings Stores all settings regarding a Layer's mapping, tiling, and rotation. »Mapping / Tiling / Rotation |
*.mfelx |
MADRIX 5 File Extension List Stores a File Extension List for the HTTP Remote Control web server. »Remote HTTP |
*.log |
Log File A logging file created with the MADRIX 5 Logfile tool or the MIDI Watcher. »Tools |
*.mas |
MADRIX 5 Script File A script for the MAS Script Effect. »MAS Script Effect |
*.macs |
MADRIX 5 Script Encrypted A compiled and encrypted script for the MAS Script Effect. »MAS Script Effect |
*.mms |
MADRIX 5 Effect Macro A Macro for an effect, a Storage Place Macro, or a Main Output Macro. »Macros And Scripts |
*.mcm |
MADRIX 5 Effect Macro Encrypted A compiled and encrypted Macro for an effect, a Storage Place Macro, or a Main Output Macro. »Macros And Scripts |
*.WibuCmRaC |
MADRIX KEY File Required if the MADRIX KEY should be upgraded or updated manually. »MADRIX KEY [Activation] |
*.WibuCmRaU |
MADRIX KEY Update File Required to upgrade or update the MADRIX KEY manually. »MADRIX KEY [Activation] |
Furthermore, MADRIX 5 supports every image and video type that is supported by your Windows PC. In most cases, a specific video codec needs to be installed on your computer in order to be able to load it.
▪Images
- Supported file formats includes: Bitmap (*.bmp), GIF (*.gif), JPEG (*.jpg, *.jpeg, *.jpe, *.jfif), PNG (*.png), TIFF (*.tif, *.tiff), MADRIX Image Table (*.mitz), MADRIX Image Table Uncompressed (*.mitx)
- Learn more »SCE Image
▪Videos
- Examples for supported file formats: ASF (*.asf), AVI (*.avi), DivX (*.divx), Flash Video (*.flv), Matroska (*.mkv), MPEG (*.mpeg, *.mpg), MPEG-2 (*.m2v), MPEG-4 (*.mp4, *.mp4v), MOV (*.mov), OGG (*.ogv), Real Video (*.ram, *.rm, *.rmvb, *.rv), VOB (*.vob), WebM (*.webm), WMV (*.wmv), Xvid (*.xvid), 3GP (*.3gp), MADRIX Record (*.mrec)
- Learn more »SCE Video
If you are encountering problems using image or video files, install the required video codec or image codec on your PC.
| MADRIX 5.7. |
