Cue List
Basic Controls
How To Work With The Cue List
Setting Up Cues
Time Code
Playback Side
Live Control
File Watcher [Automatic Cue List Reloading]
The Cue List is an automated playlist.
It offers the possibility to precisely manage the automatic playback of effects. Once the Cue List is started, MADRIX 5 will automatically play back your visuals according to your configuration and schedule. That means MADRIX 5 switches from Storage Place to Storage Place [i.e. from effect to effect].
You can open the Cue List in 3 ways:
Go to the menu Tools > Cue List...
Or press F7
Or click Layer Control > Cue List on the user interface.
To close the Cue List and change back to the original MADRIX 5 user interface:
Or press F7
Or click Cue List > Layer Control on the user interface.
Basic Controls
The main user interface offers 3 control buttons for the Cue List.
Cuelist Section
Cuelist Go
Go - Skips to the next Cue.
Cuelist Back
Back - Returns to the previous Cue.
Cuelist Play/Stop
Play/Pause - Starts or holds playback.
Layer Control > Cue List - Opens the actual Cue List window. This is the Cue List itself. Use it to set up your Cue List configuration.
Cue List Window
The Cue List window can be used in 2 modes:
A] The Cue List is part of the MADRIX 5 user interface. You can switch between different views [e.g., Layer Control, Cue List, Group Control].
B] The Cue List can be undocked and used freely as a separate window.
A] Cue List Docked
B] Cue List Undocked
Cuelist Dialog
Controls
Managing Cuelists
New - Creates a new Cue List. It also clears all entries from the current Cue List!
Open - Loads an already existing Cue List [of the file type *.mclx or *.csv]. Choose the file from your harddisk.
Open And Attach - Loads an already existing Cue List [of the file type *.mclx or *.csv] and adds it to the current Cue List.
Save - Stores your Cue List in an external file. You can choose to save in standard *.mclx file format; or to save in *.csv file format in order to easily edit the file with a text editor, for example.
Managing Entries
Add Cue - Adds a new cue to the Cue List. When a Time Code is received, MADRIX 5 will also automatically add the currently received Time Code to the cue [by filling in the column Time Code].
Remove Cues - Removes all currently selected cues from the list.
Duplicate Cues - Copies the currently selected cues and adds them as new cues to the list.
Cue - Opens a context menu with the following options.
Cue All - Adds new Cue List entries for all Storage Places that have a MADRIX 5 Effect customized and stored.
Cue Deck A - Adds new Cue List entries for the Storage Places that have a MADRIX 5 Effect customized and stored on the currently selected Deck A.
Cue Deck B - Adds new Cue List entries for the Storage Places that have a MADRIX 5 Effect customized and stored on the currently selected Deck B.
# 3 - Displays the total number of cues in the Cue List.
Swap Position - Swaps the position of cues in the list when several cues are selected first.
Position Up - Changes the order, and positions currently selected cues one item higher up in the list.
Position Down- Changes the order, and positions currently selected cues one item lower down in the list.
Control Buttons
Back - Returns to the previous cue.
Go - Skips to the next cue.
Goto - Jumps to the specified cue. Make sure to enter the correct number in the nearby input field.
Progress - Shows you the relative time progression of the current cue in a progress bar.
Undock - Allows you to undock the Cue List and use in a separate window.
Dock - Allows you to integrate the Cue List back into the user interface of MADRIX 5 when undocked.
Multiple Selection
Double-Click / Right Mouse Click - Perform a double-click or right click with the mouse onto an entry into the specific column and you will be able to enter and change the values.
Multiple Selection - The list allows you to select and modify more than one entry at a time. Select several entries by using Shift + Left Mouse or Ctrl + Left Mouse or Shift + Arrow Keys. Then, right click into the column you want to change.
Spacebar or value of -1 - Removes all values or restores the default values.
Double-Click - Perform a double-click on the very first column of the Cue List in order to start playing from this cue [thus performing a Goto]. Make sure to only double-click in the first column. You can even jump to specific cues during Cue List playback in this way.
Setting Up Cues
1] Add new cues to the Cue List by using
 A] Cue on the user interface,
 B] + in the Cue List window, or
 C] Cue All in the Cue List window.
2] Change each cue as explained in the list below.
 - Change values as described above in the section Controls
 - You can even edit the Cue List while it is playing.
 - Make sure to change the settings for each cue according to your requirements!
The first column shows the current playback state [Playing, Pause] and can also be used to perform a Goto with the mouse. Perform a double-click on the column in order to start playing from this cue. You can even jump to specific cues during Cue List playback in this way.
MADRIX 5 automatically numbers each cue consecutively with an index number, beginning with 1.
- Note: Change this index number in order to quickly change the order of cues. MADRIX 5 will automatically rearrange the list.
Description
Automatically fills in a label. This label is based on the Description field of the Storage Place on the user interface. You can change the label if you wish.
Date
Defines if the entry will be played at a specific date. You can enter 3 different types:
Daily -
This is the default value.
Enter 0, d, or D and the cue will be considered every single day.
A weekday -
Enter m or M for Monday,
t for Tuesday,
w or W for Wednesday,
T for Thursday,
f or F for Friday,
s for Saturday,
S for Sunday.
A specific date -
Use one of the following formats:
[Year Month Day]
2013/12/31
2013:12:31
2013;12;31
2013-12-31
13-12-31
[Specific Day of Current Month of Current Year]
01 - First day of this month of this year
02 - Second day
etc.
[Specific Day of Specific Month of Current Year]
01-01 - First day, first month of this year
01-02 - Second day, second month
etc.
Time Code
Defines a specific time the cue should be played. Use the hours:minutes:seconds:frames format to enter the time: HH:MM:SS:FF
Example
- 10 o'clock and 20 minutes, 30 seconds, and 10 frames
- Use one of the following formats:
10203010
10:20:30:10
10,20,30,10
10.20.30.10
10/20/30/10
10h20m30s10f
[Short versions for single items]
10h
20m
30s
10f
Offset
- Works for single or multiple cues.
- Enter + followed by a number to add an Offset. [Otherwise you are entering the Time Code anew.]
- Enter - followed by a number to subtract an Offset. [Otherwise you are entering the Time Code anew.]
Automatic Completion
- MADRIX 5 will automatically fill in the Time Code when adding a new cue [if a Time Code is received at the time].
Duration
Defines how long an effect is going to be played. The Fade Time is calculated as part of the Duration [and is thus a fade in]. Leave the Duration empty if the effect should be active as long as you do not control the Cue List manually [via Go, Back, Play/Pause, or Goto]. Use the hours:minutes:seconds:frames format to enter the time: HH:MM:SS:FF as explained under Time Code
Follow Cue
You can assign a certain cue to be played after another. As such, a Follow cue assigns the next cue the Cue List should play right after this cue. Follow cues allow you to define a certain order in which cues should be played by the Cue List. Simply enter the number of the cue that should follow. Leave empty if not required.
Storage
Defines in which Storage the effect is located. Enter a number between 1 and 256
Place
Defines the exact Storage Place, where the effect is located. Enter a number between 1 and 256
Fade
Defines the Fade Type for the crossfader when the Cue List automatically fades from one effect to another. All Fade Types of the crossfader are available here. Learn more »Crossfader
Fade Time
Defines the length of the automatic fade for the crossfader and thus creates a fade in. Enter a value in seconds:milliseconds format: SS:MM. Learn more »Crossfader
Group Preset
Defines which Group Preset is triggered together with this cue. [The Fade Time of the Cue List will automatically be used as the Fade-In Time of the Group Control.] Enter a number between 1 and 256. Leave empty if not required. Learn more »Fixture Groups [Group Control]
Time Code
Timecode
Time Code is a useful option to trigger effects at certain times of the day or at certain points in time. For example, you might want to trigger Storage Place S1 P1 at 10:00 a.m. or when 3 minutes have passed after the start. Time Code is a convenient way to synchronize independent equipment of your LED installation with each other. This could be external audio equipment, other MADRIX 5 computers, or even the same computer. You might want to set up a time-controlled show in sync with timelines of lighting effects of MADRIX 5 and sound.
Configuration
Time Code Source - Select from which source Time Code should be received.
- None - Deactivates the usage of Time Code.
- Art-Net - Receives Art-Net Time Code from an Art-Net source [for example, a console, another software, the »MADRIX 5 Time Code Sender, etc.]. You need to activate Art-Net first. Learn more »Art-Net [DMX Over Ethernet]
- MIDI - Receives MIDI Time Code from a MIDI source. You need to activate MIDI first. Learn more »MIDI-IN Configuration
- SMPTE - Receives SMPTE Time Code from the MADRIX USB SMPTE hardware interface. Learn more »MADRIX I/O
- System Time - Uses the internal computer clock [i.e. the clock of the operating system] to generate the Time Code. If the time of your computer system is 10:00 a.m., the generated Time Code will be 10:00:00:00, for example.
Time Code Format - Allows you choose between different Time Code formats. When receiving Time Code from an external source, use the format sent by the external source. You can choose from:
- 24 FPS
- 25 FPS
- 30 Drop [30/1.001 FPS]
- 30 FPS
00:00:00:00
Displays the currently used Time Code. The hours:minutes:seconds:frames format is used: HH:MM:SS:FF
Learn more »Time Code [MIDI / Art-Net / SMPTE / System Time]
Stop
According to your configuration, you may have to set the Time Code Source to None to fully stop the Cue List.
Do not forget to save your Cue List or the complete MADRIX 5 Setup file.
When you are using Date, Time Code, and/or Duration, logical routines are implemented to determine which cue should be currently active. These routines are explained in more detail below.
Date
If you are setting up a Date for a cue, 3 options are available to you:
Daily,
A specific weekday,
Or an explicit date.
If you are using a mixture of those three options, a cue will be favored and activated according to the following hierarchy if applicable:
An explicit date overrides a weekday entry. And a weekday entry overrides a daily entry.
For example, daily will activate a cue every single day. But on Mondays, another cue should be activated and it will be. But 2010/04/19 is also a Monday and this cue will be activated this day instead of the daily cue and instead of the Monday cue.
Time Code Without Duration
If you are using the column Time Code without the column Duration, a cue will only be activated if the Time Code passes this predefined time.
If the Time Code of a cue [without Duration] has already passed that deadline, the cue will not be activated.
Time Code With Duration
A] If you are using the column Time Code and the column Duration, a cue will be activated when the current Time Code falls into this time window.
A cue using Time Code and Duration will be activated if it falls into the time window.
In addition, the logical routine will check if the Date needs to be considered according to the information above [Date].
For example, if your daily cue should start at 8 o'clock for 8 hours and the current Time Code says 10 o'clock, the cue will be activated.
B] When using Time Code and Duration, you should be aware of what should happen when the Duration is over. A cue with a Time Code and Duration will expire eventually.
When a cue with Time Code and Duration is over or has expired, MADRIX 5 will automatically select the next cue; regardless of what the next cue is.
MADRIX 5 will not check if the next cue is valid or logic. If you do not want MADRIX 5 to select the next cue, use Follow cues for example or make sure the next cue is set up correctly!
Loop Function
If all cues have been assigned a Duration, the Cue List will automatically start from the beginning again after the last cue.
If a cue inside the Cue List does not have a pre-defined duration, the Cue List will stop at this cue.
If you want to stop the Cue List with the last entry, you only have to remove the duration for the last cue in your Cue List.
Playback Side
You can choose how MADRIX 5 manages the user interface when playing back the Cue List.
Go to the menu Preferences > Options... > User Interface
[Keyboard shortcut: Ctrl+Alt+O > User Interface]
User Interface
Playback Side - Defines which sides are used during Cue List playback. Choose from 2 modes:
Alternating - MADRIX 5 automatically switches from side to side between Deck A and Deck B.
- Example: The first Cue will be played on Deck A of the user interface, the second Cue on Deck B, the third Cue on Deck A again, and so on.
By Storage ID Parity - MADRIX 5 will decide which side to use depending on the Storage ID.
- Cues that refer to an odd Storage ID [e.g., Storage 1 or Storage 3] will be played back on Deck A only.
- Cues that refer to an even Storage ID [e.g., Storage 2 or Storage 4] will be played back on Deck B only.
D - Restores the default settings. The default value is By Storage ID Parity.
Click Apply to confirm.
Click OK to close the window.
Live Control
The majority of controls in MADRIX 5 is disabled while the Cue List is running. The following control controls are available to you even during Cue List playback:
Cue List and Cue List controls
Submaster Deck A / Deck B
Color Filter Deck A / Deck B
Speed Masters Deck A / Deck B, including Pause
Learn more »Controls [Deck A / Deck B]
Crossfader
Main Output Color Filter
Main Output Filter
Main Output Strobe
Master, including Freeze and Blackout
Audio Output Level, including Mute
Audio Input Level, including AGC and Mute
Learn more »Main Output / Master / Audio Levels
Group Control
MADRIX 5 can automatically reload a Cue List within a predefined refresh time.
Learn more »General
