MADRIX KEY [Activation] |
Please activate your MADRIX KEY first, when using the MADRIX 5 Software for the first time
Please follow the steps described in the MADRIX 5 Quick Start Guide or below: 1] Make sure you are online. An active internet connection is required for the activation. 2] Download the latest MADRIX 5 Software from www.madrix.com or use at least MADRIX in version 5.2. 3] Connect the MADRIX KEY to your computer and install the MADRIX 5 Software. 4] Start MADRIX 5 now and go to the menu Help > MADRIX KEY > Activate MADRIX KEY...
5] Enter your ticket number and follow the on-screen instructions. Double-check your MADRIX 5 License in the menu Help > About...
For the update process, you might be asked to manually create files from the MADRIX KEY. Please follow the steps below: 1] Connect exactly one MADRIX KEY to your computer! And a new window will open. 4] Click Create RaC File. 5] You will receive a new RaU file from your supplier by e-mail. 6] Go again to Help > MADRIX KEY > Update MADRIX KEY... and click Update MADRIX KEY 7] Select the RaU file on your harddisk and click OK 8] After the successful update, the software will automatically create a new receipt file. 9] Restart MADRIX 5. 10] Double-check if the update or upgrade was successful under Help > About...
MADRIX 5.6. |
