File Types
File Types
MADRIX 3 File Types
Images And Videos
Loading A MADRIX Setup File
You will come across several file types, while working with MADRIX. This chapter explains which file type belongs to which function or which part of the software.
MADRIX 3 File Types
*.msz
*.msx
MADRIX Setup
MADRIX Setup Uncompressed
Your whole show will be saved. It stores relevant data in one single file; including but not limited to Patch, effects, settings, Cue List, images, etc.
Note: Videos will not be included in this file, for example.
*.msz.msbackup
Backup of a MADRIX Setup
Stores MADRIX Setups automatically as backup files as set up in the file recovery options of the software. »General
*.mpz
*.mpx
MADRIX Patch
MADRIX Patch Uncompressed
Stores your Patch. »Patch Editor
*.mflx
MADRIX Fixture Library
Stores the whole Fixture Library. »MADRIX Fixture Editor
Note: The madrix.mflx is being overwritten with an updated version every time a new MADRIX version [software update] is installed.
*.mfxx
MADRIX Fixture
Stores one single fixture. »MADRIX Fixture Editor
*.mstz
*.mstx
MADRIX Storage
MADRIX Storage Uncompressed
Stores a complete Storage including all of its Storage Places [i.e., effects]. »Storages
*.mspz
*.mspx
MADRIX Storage Place
MADRIX Storage Place Uncompressed
Stores one single Storage Place, and thereby one effect you created. »Storage Places [256 x 256]
*.mdmxx
MADRIX DMX Device Settings
Stores all relevant settings for your [connected] DMX devices. »OUTPUT Settings
*.mdvix
MADRIX DVI Device Settings
Stores all relevant settings for your [connected] DVI devices. »OUTPUT Settings
*.mvisx
Visualizer Device Settings
Stores all relevant settings for a configured 3rd-party visualizer. »WYSIWYG Visualizer
*.mpdx
MADRIX PLEXUS Device Settings
Stores all relevant settings for a MADRIX PLEXUS interface. »MADRIX PLEXUS
*.xml
MADRIX PLEXUS Configuration
Stores a PLEXUS Configuration, i.e. show, for a MADRIX PLEXUS interface. »MADRIX PLEXUS
*.mldx
MADRIX LUNA Device Settings
Stores all relevant settings for a MADRIX LUNA interface. »MADRIX LUNA
*.mndx
MADRIX NEBULA Device Settings
Stores all relevant settings for a MADRIX NEBULA interface. »MADRIX NEBULA
*.msdx
MADRIX STELLA Device Settings
Stores all relevant settings for a MADRIX STELLA interface. »MADRIX STELLA
*.mmrx
MADRIX MIDI Remote Configuration
Stores a MIDI Remote Configuration [MIDI map] for a MIDI controller for the MIDI Remote Editor. »MIDI-IN
*.mdrx
MADRIX DMX Remote Configuration
Stores a DMX Remote Configuration for DMX-IN for the DMX-IN Remote Editor. »DMX-IN / Art-Net Remote / sACN Input
*.mrec
MADRIX Record
Stores recorded effects. »Recording
*.dxd
MADRIX DMX Data
Stores DMX data for the MADRIX PLEXUS hardware interface. »Recording
*.mclx
MADRIX Cue List
Stores the Cue List and its entries as well as settings. »Cue List
*.csv
Comma-Separated Values
A file format that can be used for the Cue List. »Cue List
*.mgcz
*.mgcx
MADRIX Group Control
MADRIX Group Control Uncompressed
Stores the Group Control including fade-in time, Group Presets, and current values. »Fixture Groups
*.mitz
*.mitx
MADRIX Image Table
MADRIX Image Table Uncompressed
Stores an Image Table for the SCE Image effect including the images. »SCE Image
*.mctx
MADRIX Color Table
Stores color information [Color Table, Gradient, M2L Color Table, etc.] for various MADRIX effects. »Using Colors And Intensity
*.mstrtx
MADRIX String Table
Stores a String Table including its strings and characters for the SCE Counter effect. »SCE Counter
*.mepcz
*.mepcx
MADRIX Effect Parameter Chaser
MADRIX Effect Parameter Chaser Uncompressed
Stores an Effect Parameter Chaser including its Step list for a Layer. »Chaser
*.msppcz
*.msppcx
MADRIX Storage Place Parameter Chaser
MADRIX Storage Place Parameter Chaser Uncompressed
*.mgvcz
*.mgvcx
MADRIX Group Value Chaser
MADRIX Group Value Chaser Uncompressed
Stores an Group Value Chaser including its Step list for the Group Control. »Fixture Groups
*.mmapx
Map Settings
Stores all settings regarding a Layer's mapping, tiling, and rotation. »Mapping / Tiling / Rotation
*.mfelx
MADRIX File Extension List
Stores a File Extension List for the HTTP Remote Control web server. »Remote HTTP
*.log
Log File
A logging file created with the MADRIX Logfile tool or the MIDI Watcher. »Tools
*.mas
MADRIX Script File
A script for the MAS Script Effect. »MAS Script Effect
*.macs
MADRIX Script Encrypted
A compiled and encrypted script for the MAS Script Effect. »MAS Script Effect
*.mms
MADRIX Effect Macro
A Macro for an effect, a Storage Place Macro, or a Main Output Macro. »Macros And Scripts
*.mcm
MADRIX Effect Macro Encrypted
A compiled and encrypted Macro for an effect, a Storage Place Macro, or a Main Output Macro. »Macros And Scripts
*.rtc
*.WibuCmRaC
MADRIX KEY File
Required if the MADRIX KEY should be upgraded or updated. »MADRIX KEY [Software License]
*.rtu
*.WibuCmRaU
MADRIX KEY Update File
Required to upgrade or update the MADRIX KEY eventually. »MADRIX KEY [Software License]
*.mnlc
MADRIX NEO License Context File
Required if the MADRIX NEO license should be updated. »Update From MADRIX 2.X To MADRIX 3.X
*.mnlu
MADRIX NEO License Update File
Required to update the MADRIX NEO license eventually. »Update From MADRIX 2.X To MADRIX 3.X
Images And Videos
Furthermore, MADRIX supports every image and video type that is supported by your Windows PC. In most cases, a specific video codec needs to be installed on your computer.
Images
Examples: *.bmp, *.gif [including animated GIFs], *.jpg, *.png, *.tif, *.tiff
Learn more »SCE Image
Videos
Examples: *.avi, *.mpg, *.mov, *.wmv, *.asf, *.divx, *.vob, *.flv, etc.
Learn more »SCE Video
If you are encountering problems using such files, please install the required video codec or image codec on your PC.
As described above, a MADRIX Setup File stores a lot of information. When loading a Setup, you have different choices to make:
Open Options When Loading A Setup
Load Patch - Will load the pre-defined virtual matrix and Patch settings from this Setup. This overwrites your current Patch. If you deselect this option, your current Patch will be used.
Load Group Control - Will load the Group Control from this Setup. This overwrites the current Group Control. If you deselect this option, your current Group Control settings will be used.
Load DMX Device Settings - Loads all settings regarding DMX devices from this Setup. This can overwrite your current settings. Deselect this option if you have configured your own DMX settings.
Load DVI Device Settings - Loads all settings regarding DVI devices this Setup. This can overwrite your current settings. Deselect this option if you have configured your own DVI devices settings.
Load Audio Performance Settings - Loads all settings regarding audio this Setup. This can overwrite your current settings. Deselect this option, if you wish to keep your own audio settings.
MADRIX 3.6i
