MIDI-IN
Interruption-Free Operation
Step-By-Step Configuration
MIDI Audio
MIDI Remote Control
MIDI Time Code
MIDI Watcher
MIDI Logo
MIDI [short for Musical Instrument Digital Interface] is a widely-known communication standard and digital interface.
In MADRIX, there are mainly 3 areas of application for MIDI:
Using MIDI controllers for Remote Control
Using MIDI devices for audio input via MIDI
Using MIDI Time Code
MIDI devices are often simply connected directly via USB or via a MIDI-to-USB interface to the computer.
MIDI Time Code will be explained in the next chapter. Learn more »»Time Code [Art-Net / MIDI / SMPTE / System Time]
To ensure interruption-free operation of the software and devices, please make sure to check the power-saving settings of Windows.
Learn more »PC Power Management
1] Connect your MIDI device.
2] Set up MIDI and enable your device.
3] Choose how to use the device and incoming signals.
1] Connect Your MIDI Device
Connect your controller to the computer.
Make sure that Windows recognizes the device and install drivers if necessary.
2] Set Up MIDI
Go to Preferences > Remote Control > MIDI...
or Preferences > Device Manager... > MIDI
[Keyboard shortcut: F4 > MIDI ]
A new window will open.
MIDI Configuration
Click
MADRIX will automatically search for connected devices.
Your MIDI device will be shown in the list.
MIDI Configuration
Select your device in the list.
Activate Enable
[Please note that the State in the list will change from Off to On.]
MIDI Configuration
3] Choose How To Use MIDI
Now, several options are available to you:
Audio - Activates your MIDI device to be used as audio source [a MIDI keyboard, for example].
Learn more MIDI Audio
Remote - You can use your MIDI VJ/DJ controller or console to control MADRIX remotely.
Learn more MIDI Remote Control
MTC - You can use MADRIX to receive external MIDI Time Code.
Learn more MIDI Time Code
Watch - Launches the MIDI Watcher to monitor incoming signals or troubleshoot.
Learn more MIDI Watcher
You can activate several MIDI devices at the same time.
You can use all options at the same time [Audio, Remote, MTC, Watch].
MIDI Audio
Activate your MIDI device as explained above.
Again, go to Preferences > Remote Control > MIDI...
Activate Audio
[Please note that Audio in the list will change from Off to On.]
Now, the Audio section below will be activated.
MIDI Audio
Use For S2L - Activates the audio analysis of incoming MIDI signals for Sound2Light effects. This option is activated by default.
Use For M2L - Activates the audio analysis of incoming MIDI signals for Music2Light effects. This option is activated by default.
Channel Selection - Defines which MIDI channel will be scanned and used by MADRIX.
- In general, MIDI offers 16 channels. You can configure each MIDI device to send on a particular channel. Make sure that this channel is also selected in this section here.
- If you wish to filter a channel, deselect the according number. As a result, the channel will not be used for MIDI-IN in combination with MADRIX.
- By default, all 16 channels are activated and will be used by MADRIX.
MIDI Remote Control
Configuration
Activate Remote
[Please note that Remote in the list will change from Off to On.]
Now, the Remote Control section below will be activated.
MIDI Remote Control
Open MADRIX MIDI Remote Configuration
Open - Loads a previously saved MADRIX MIDI Remote Configuration file [of the file type *.mmrx].
MIDI Configuration
MIDI Maps - Choose from a pre-configured MIDI map [configuration].
Learn more MIDI Maps [Overview]
If you wish to create a new MIDI map, choose USER User.
You can edit every MIDI map. Learn more »MIDI-IN Remote Editor
MIDI Remote Control Edit
MIDI Remote Editor - Allows you to modify a configuration or create a new configuration. Learn more »MIDI-IN Remote Editor
MIDI Commands
MADRIX can receive the following MIDI command types:
Control Change
Note
Pitch Bend
Program Change
MADRIX includes a number of preprogrammed MIDI maps. Learn more in the following chapters.
»Akai Professional APC40
»Akai Professional APC40 MKII
»Akai Professional APCkey25
»Akai Professional APCmini
»Akai Professional LPD8
»Akai Professional LPK25
»Akai Professional MIDIMIX
»Akai Professional MPK249
»Akai Professional MPK261
»Akai Professional MPKmini MKII
»Behringer BCD3000
»Behringer BCF2000
»Behringer BCR2000
»Creative Prodikeys PC-MIDI
»Elation Professional MIDICON
»Hercules DJ Console Rmx
»Hercules DJ Control MP3 And DJ Console MK2
»Hercules DJ Control MP3 e2
»KORG nanoKONTROL
»KORG nanoKONTROL2
»Livid Instruments Ohm64
»M_AUDIO Code 49
»M-AUDIO Oxygen 8 v2
»M-AUDIO Torq Xponent
»MIDI Keyboards
»MIDI Universal
»Novation Launchpad
»Numark NuVJ
»Numark Omni Control
»Numark Stealth Control
»Numark Total Control
»Omnitronic MMC-1
»Stanton SCS.3d
»USER User
»Vestax VCI-100
»Vestax VCM-100
MIDI Time Code
Activate MTC
[Please note that MTC in the list will change from Off to On.]
Now, you can receive MIDI Time via the Cue List.
MIDI Watcher
Activate Watch
[Please note that Watch in the list will change from Off to On.]
It is now possible to monitor incoming MIDI signals.
Click MIDI Watcher...
You can now check incoming signals.
Learn more »Tools
Before using a MIDI device, please make sure that your MIDI device is connected to your computer and that all necessary drivers are installed.
Please also make sure to save your MADRIX Setup after following configuration process.
