MADRIX uses so-called Storage Places [storage bins] to store and organize your lighting visuals.
▪ | Storage Places are part of a Storage.
[Because of this, a Storage offers options that affect a single Storage Place or all of its included Storage Places.] |
▪ | The screenshot below shows the complete Storage Left including the numbered Storage Places [Storage Place 1 to 64 can be seen by default]. Learn more »Storages |
▪ | A single Storage contains 256 Storage Places. And MADRIX offers up to 256 Storages. |
▪ | In total, you have therefore access to 256 x 256 Storage Places. |
Workflow
▪ | Storage Places allow you to access, manage, and organize your different lighting visuals. |
Controls
▪ | Shows an empty Storage Place with its default configuration.
[The default MADRIX Effect is: SCE Color with the color Black.] |
▪ | Shows a preselected Storage Place, which is not active yet. |
▪ | Shows the currently selected Storage Place. This Storage Place is active on the selected Storage. |
▪ | Shows that this Storage Place contains visuals configured by you. The Storage Place is occupied and not empty. |
▪ | Shows a Storage Place that is currently selected on the other side. You can only select a Storage Place once on either side. This Storage Place is shown already on the left or the right side and cannot be accessed. |
▪ | You can increase the size of a Storage Place as shown on the user interface [Learn more »Storages]. When the size is large enough, MADRIX will include a small Thumbnail preview of the MADRIX Effect that is stored in the Storage Place. Learn more below. |
▪ | You can decrease the size of a Storage Place as shown on the user interface [Learn more »Storages]. When the size is too small, MADRIX will only show small icons. |
▪ | Shows a Thumbnail. Hover with your mouse over a single Storage Place in order to see a small preview of the MADRIX Effect that is stored in the Storage Place. The Thumbnail can be generated automatically or manually. Learn more below |
▪ | The Preview Windows will show you which Storage [e.g., S1] and which Storage Place [e.g., P42] you have currently selected. |
▪ | The scroll bar at the bottom shows the lowest Storage Place that is currently visible on the Storage Place panel. You can also use it for scrolling through the panel. |
▪ | Is part of the scroll bar and shows the location of occupied Storage Places. |
▪ | Is part of the scroll bar and shows the location of the currently selected Storage Place. |
Working With Storage Places
Using The Mouse
▪ | Left Mouse Click - Click with your left mouse button directly on a single Storage Place to select and activate it. MADRIX will automatically fade to the new Storage Place according to the Fade Time and Fade Type of the crossfader. |
▪ | Left Mouse Double-Click - Perform a double-click with your left mouse button directly on a single Storage Place to select and activate it immediately without using the Fade Time and Fade Type of the crossfader. |
▪ | Right Mouse Click - Calls up the context menu as explained below. |
▪ | Left Mouse Click And Hold And Swipe/Drag - Click with your left mouse button in the general direction of the Storage Place panel, continue to hold, and move your mouse in order to swipe and drag the entire panel. This allows you to navigate through the Storage Place panel. [You can also use the scroll bar at the bottom.] |
▪ | Scroll Wheel - Click in the the general direction of the Storage Place panel to focus it. Then, use the scroll wheel of your mouse to scroll through the panel. |
▪ | Click with your left mouse on this scroll bar to scroll through the Storage Place panel. |
Automatic Fade
▪ | MADRIX automatically applies an automatic fade according to the Fade Time and Fade Type of the Crossfader when you are switching from one Storage Place to another Storage Place within one, single Storage. |
▪ | Example: S1 P34 is currently selected. Now, select S1 P22 and MADRIX will automatically do a crossfade for you [incl. Fade Time and Fade Type]. |
▪ | [Perform a Left Mouse Double-Click to not use the automatic fade. This will activate the next Storage Place without a crossfade.] |
Drag And Drop [Copy/Cut/Paste]
Copy And Paste
▪ | Left Mouse Click and 2 Sec. Hold - You can perform a Copy and Paste with the mouse.
Use a left mouse click on a Storage Place and continue to hold for 2 seconds. A small + appears. Continue to hold and move your mouse to another Storage Place. Release the mouse button to paste a copy onto the new Storage Place. |
Cut And Paste
▪ | Left Mouse Click and 2 Sec. Hold + Shift - You can perform a Cut and Paste with the mouse.
Use a left mouse click on a Storage Place and continue to hold for 2 seconds. Press Shift in addition. A small rectangle appears. Continue to hold the buttons and keys and move your mouse to another Storage Place. Release the mouse button to move the previously selected Storage Place to the new position. |
Drag And Drop
▪ | File Drag And Drop - You can select a MADRIX Storage Place file [of the file type *.mspz or *.mspx] in Windows and drag it to a Storage Place of your choice in MADRIX in order to load it in MADRIX. |
Keyboard Shortcuts
▪ | Arrow Keys - Use the 4 arrow keys on your computer keyboard to navigate and in order to preselect a specific Storage Place. |
▪ | Spacebar/Enter - Press the Spacebar or Enter key on your keyboard to actively select a preselected Storage Place. |
▪ | Page Up/Page Down - Press the Page Up and Page Down keys to scroll through the Storage Place panel back and forth. |
▪ | Home/End - Press the Home key to instantly display the first Storage Place [P1]. Press the End key to instantly display the last Storage Place [P256]. |
▪ | F - Press F to instantly jump back to your currently selected Storage Place and to bring it into focus. |
Context Menu
There are several options available for each Storage Place via a context menu.
▪ | Right Mouse Click on a Storage Place to call up the context menu. |
▪ | Or go to Edit > Storage Place Left/Right |
▪ | A small window will be shown. |
You can use the following options:
▪ | Cue - Adds the currently selected Storage Place to the Cue List.
▪ | Open... - Loads a previously saved MADRIX Storage Place file [of the file type *.mspz or *.mspx]. A new window opens for you to select the file on your harddisk. |
▪ | Save... - Saves the current Storage Place configuration to an external file [of the file type *.mspz or *.mspx]. A new window opens for you to select a location on your harddisk. Simply enter a name and click Save
▪ | Copy - Copies the current Storage Place configuration into the clipboard as a duplicate. |
▪ | Cut - Copies the current Storage Place configuration into the clipboard and applies a Clear |
▪ | Paste - Inserts a copy of a Storage Place from the clipboard into the currently focused Storage Place.
▪ | Thumbnail - Defines how MADRIX manages the Thumbnail of the currently selected Storage Place. Learn more below
▪ | Clear - Removes the current Storage Place configuration and restores the default, blank Storage Place. |
Thumbnails
When using the context menu of a Storage Place, you can set up how MADRIX manages the Thumbnail of each individual Storage Place. First, make sure that the currently selected Storage Place is also the active Storage Place of this Storage.
[Or go to Edit > Storage Place Left/Right > Thumbnail] |
▪ | Automatic - Is activated by default. MADRIX will automatically generate a new Thumbnail each time you leave this Storage Place and switch to another Storage Place. That means the Thumbnail preview will always be up to date and show the last visual status. |
▪ | Generate - Allows you to manually generate a new Thumbnail at this moment. Automatic will then be deactivated as a result. Once a manual Thumbnail has been generated, MADRIX will use this Thumbnail until you manually generate a new Thumbnail or activate Automatic again. |
Export / Import
Import
Learn more »File Types
File Menu
▪ | Go to File > Import > Storage Place > Storage Left/Right... |
▪ | You can import previously saved MADRIX Storage Place file [of the file type *.mspz or *.mspx] onto the currently selected Storage Place on the left or on the right side. A new window opens for you to select the file on your harddisk. [This is the same functionality as Open... from the context menu.] |
Drag And Drop
Export
File Menu
▪ | Go to File > Export > Storage Place > Storage Left/Right...
You can export the currently selected Storage Place to an external file [of the file type *.mspz or *.mspx]. A new window opens for you to select a location on your harddisk. Simply enter a name. [This is the same functionality as Save... from the context menu.] |
▪ | Go to File > Export > Storage Place > All...
You can export all currently occupied Storage Place to individual, external files [of the file type *.mspz or *.mspx]. A new window opens for you to select a location on your harddisk. Simply enter one name and MADRIX will automatically add the Storage Place number to the file as well. |
Important Information
▪ | Make sure to save your MADRIX Setup file after configuring your MADRIX Effects [and working with Storage Places]. |
▪ | When switching to a different Storage, MADRIX will not automatically select a new Storage Place for you. When switching to another Storage, you need to actively select a different Storage Place if that is what you want. |
