MADRIX Fixture Editor
Usage
Where To Find
More Information
LED fixtures are implemented using the MADRIX Fixture Editor. The fixtures are stored in the MADRIX Fixture Library [madrix.mflx].
Fixture Editor
Usage
With the help of the MADRIX Fixture Editor, you can
see how fixtures are integrated in MADRIX,
see how many and which fixtures are already included,
adjust settings to your requirements,
implement and add fixtures to the library yourself.
Where To Find
MADRIX Fixture Editor is included in the MADRIX Installer. After installing MADRIX, you can find the link to the tool in the Windows Start menu:
Start > All Programs > MADRIX 3 > Fixture Editor
The original, executable program can be found in the MADRIX installation directory:
C:\Program Files (x86)\MADRIX3
Always make a backup of the madrix.mflx before and after applying any changes.
When updating your MADRIX version, the Setup [Auto Installer] will automatically create a "madrix.mflx.bak". This file is a backup of your old MADRIX Fixture Library. Moreover, the Setup will overwrite the current madrix.mflx completely to update the library.
Please quit MADRIX before using the Fixture Editor and making any changes to the MADRIX Fixture Library.
More Information
You can learn more in the separate user guide for the MADRIX Fixture Editor.
MADRIX 3.6i
