MADRIX LUNA
Operating Modes
3rd-Party Controllers
Important Note
DMX-OUT Via Ethernet Network [Art-Net]
Sync Mode
Additional Art-Net Device Settings
DMX-OUT Via USB
DMX-IN Via Ethernet Network [Art-Net Remote]
DMX-IN Via USB
Status Indicators [ArtAddress]
DMX Watcher
Automatic HTP Merging
Reset To Factory Default Settings
Firmware Updates
LED Status Codes
Web Configuration
MADRIX Device Configuration
MADRIX LUNA Updater
MADRIX LUNA is an easy-to-use and reliable Art-Net node or DMX512 USB interface.
The MADRIX LUNA reliably distributes DMX512 data over long or short distances using Ethernet network or USB. The exclusive MADRIX Sync Mode makes sure that lighting effects look their best on the LEDs.
An additional MADRIX KEY [i.e., a software license] is required for usage with MADRIX.
3 versions are available:
MADRIX LUNA 4
MADRIX LUNA 8
MADRIX LUNA 16
Operating Modes
You can mainly use 4 operating modes together with MADRIX:
DMX-OUT Via USB
DMX-IN Via USB
Notes:
DMX-OUT and DMX-IN can be used at the same time.
You always have 1 to 4/8/16 output ports available [DMX 1 - 4/8/16].
- In total, 2048 DMX channels can be sent per LUNA 4 unit.
- In total, 4096 DMX channels can be sent per LUNA 8 unit.
- In total, 8192 DMX channels can be sent per LUNA 16 unit.
You always have 1 DMX input port available per unit [DMX-IN].
- In total, 512 DMX channels can be received per unit.
MADRIX LUNA is a standard Art-Net node. Because of this, you can use the device with applications, consoles, desks, or controllers that are compatible with Art-Net to distribute Art-Net data via Ethernet network.
Important Note
Make sure to read the provided MADRIX LUNA Quick Start Guide first!
»help.madrix.com
You can connect the LUNA via Ethernet network to the network card of your computer that runs the MADRIX software. Data is sent to the LUNA via network [Ethernet] and distributed to the XLR output ports [DMX 1 - 4/8/16].
1] Initial Configuration
Connect your LED controllers or fixtures to the XLR ports of MADRIX LUNA [DMX 1 - 4/8/16].
Connect MADRIX LUNA to power.
[Please see safety instructions in the MADRIX LUNA Quick Start Guide!]
Connect MADRIX LUNA to your computer using network cabling.
It is highly recommended to only use Gigabit Ethernet network components [network card, switches, etc.].
2] Windows Network Settings
Art-Net is a network-based protocol. MADRIX will use the network card of your computer to send data.
You must use these IP address and Subnet mask settings. Otherwise, Art-Net might not work!
The IP addresses of your computer and your MADRIX LUNA devices need to be different.
Set up an individual IP address in the following IP address range:
- 2.0.0.1 ... 2.255.255.254 or
- 10.0.0.1 ... 10.255.255.254
- 255.0.0.0
[Via factory default settings, MADRIX LUNA devices will have an IP address in the 10.x.x.x network range, such as 10.206.224.100, for example].
Restart MADRIX, if you have changed the network settings in Windows while MADRIX was running.
Example for PCs that are running MADRIX:
Windows TCP/IP Configuration
3] Fixture Configuration In MADRIX
Start MADRIX.
Configure the virtual LED matrix using the »Matrix Generator or »Patch Editor
4] Activating Art-Net
Go to Preferences > Device Manager... > Art-Net
Activate the checkbox Enable [in the upper, right corner].
MADRIX will automatically create the entry ArtNet Remote
This device is used only for Remote Control. Learn more DMX-IN Via Ethernet Network [Art-Net Remote]
5] Adding Devices Automatically
MADRIX can automatically add your MADRIX LUNA devices.
Click
[MADRIX will automatically search the network for connected MADRIX LUNA devices. Devices that are found will appear in the list. A number of entries will be created in the list for each LUNA device.]
[The Art-Net standards only supports a maximum of 4 output ports per device. Since LUNA 8 features 8 ports plus 1 IN port, 3 list items are created in MADRIX, for example. Two entries will be shown for LUNA 4. Five entries will be shown for LUNA 16.]
6] Activating Devices
Each of your MADRIX LUNA devices and its ports need to be activated. By default, they are still deactivated. 4 output ports will be shown for LUNA 4, 8 output ports will be shown for LUNA 8, and 16 output ports will be shown for LUNA 16.
[Keyboard shortcut: F4]
Select your devices and their ports in the list.
Activate Enable
Output is activated by default.
Click Apply
[In the screenshot above, one LUNA 8 is connected. If more devices are connected, please use the different IP addresses of different devices to identify them in the Device Manager. You can also click on Device Name as well as Universe or other columns to sort the list accordingly.]
7] Configuration Of DMX Output
Make sure that your devices are still selected under Preferences > Device Manager... > DMX Devices
Set up Universe
- Enter the specific DMX universe number.
Make sure the correct universe is assigned according to your requirements.
Learn more »Glossary
Click Apply
By default, DMX universe 1 - 4/8/16 are assigned to the ports DMX 1 - 4/8/16 when using one MADRIX LUNA:
LUNA Output Port
Name under Device Manager... > DMX Devices
DMX 1
BindIdx1 Port:0
DMX 2
BindIdx1 Port:1
DMX 3
BindIdx1 Port:2
DMX 4
BindIdx1 Port:3
DMX 5
BindIdx2 Port:0
DMX 6
BindIdx2 Port:1
DMX 7
BindIdx2 Port:2
DMX 8
BindIdx2 Port:3
DMX 9
BindIdx3 Port:0
DMX 10
BindIdx3 Port:1
DMX 11
BindIdx3 Port:2
DMX 12
BindIdx3 Port:3
DMX 13
BindIdx4 Port:0
DMX 14
BindIdx4 Port:1
DMX 15
BindIdx4 Port:2
DMX 16
BindIdx4 Port:3
8] Frame Time
Make sure that your device is still selected under Preferences > Device Manager... > DMX Devices
Set up Frame Time (ms)
Click Apply
[When using Art-Net, the Frame Time [ms] can be individually set for each port. But it cannot be set individually for each port, when Sync Mode is activated. Learn more below.]
9] Optimized Frames Or Full Frames
Activate or deactivate Send Full Frames
- Per DMX512 standard, MADRIX only sends the number of DMX channels that is configured. For example, if you are using 312 DMX channels on a DMX universe, only 312 DMX channels will be sent with every single frame on this universe [Optimized Frames].
- Activate Send Full Frames if devices should always send full frames on a particular universe, instead of optimized frames. Sending full frames means that always the full 512 DMX channels of a DMX universe will be sent with every frame [even when you are using less than 512 channels].
- Activating Send Full Frames is recommended if problems with the data output on your LEDs occur.
Click Apply
In addition, you can activate Full Frames for the device and each MADRIX LUNA output port separately.
Learn more MADRIX Device Configruation
Sync Mode
MADRIX LUNA can use the special sync mode of MADRIX.
Large LED projects require dependable data distribution. The MADRIX software and LUNA hardware allow you to synchronize data output for all 4/8/16 DMX ports and even across multiple LUNA devices to get an optimal image on the LEDs.
When MADRIX Sync mode is activated, MADRIX and MADRIX LUNA will automatically handle the synchronization of data.
MADRIX Sync Mode is highly recommended for MADRIX LUNA!
Sync Button
Sync Mode - Allows you to activate or deactivate the usage of sync packages for Art-Net.
Before activating sync, make sure that all activated Art-Net devices are available in your network! Else, the frame rate of Art-Net might drop. If you are not sure, do not enable any sync mode.
Click Sync...
A new window will open.
Select the network for which you want to activate Sync Mode.
Click Enable to activate the Sync Mode for the selected network.
A] Choose Pre-Sync to send sync packages before Art-Net data.
B] Choose Post-Sync to send sync packages after Art-Net data.
Click OK
Sync Mode Options
To disable sync mode, click Sync... again, select the correct network, and deactivate Enable. Confirm with OK
It is very important to set up the correct settings for your devices!
Broadcast Mode Or Direct IP Mode
MADRIX can send Art-Net data in 2 ways to your Art-Net devices:
Broadcast Mode - Means that every packet sent from a single transmitter will be received by all recipients in the network. MADRIX will send data to all devices in the network.
- Advantage: The same data [e.g., DMX universe 1 and 2] can be made available for different points of your setup.
- Disadvantage: A potentially huge number of data packages will be sent over the network. This can reduce the overall network performance and cause data issues or instability.
Direct IP Mode - Means that the specific data will only be sent to the specified recipient.
- Advantage: Data traffic is reduced immensely, which means that a larger number of Art-Net devices can be used in one network. Reduced network traffic increases the performance and stability.
- Disadvantage: The network settings of all devices need to be 100% correct.
Direct IP Mode is recommended in general.
Select your device in the list.
Click
A] Choose Direct IP Mode to activate Direct IP mode:
- Make sure to enter the correct IP Address of your device that should receive the Art-Net data. When MADRIX LUNA has been automatically found by MADRIX, the IP address will be pre-configured for you.
- MADRIX will send the corresponding data only to this device.
B] Choose Broadcast Mode to activate Broadcast Mode:
- Make sure to select the correct Network card of your computer that should send the Art-Net data. When MADRIX LUNA has been automatically found by MADRIX, the correct network will be pre-configured for you.
- MADRIX will send data to the whole Art-Net network.
Click Apply
More Information About Art-Net
Learn more »Art-Net [DMX Over Ethernet]
DMX-OUT Via USB
You can connect the LUNA directly via USB to the computer that runs the MADRIX software. Data is sent to the MADRIX LUNA via USB and distributed to the XLR output ports [DMX 1 - 4/8/16].
Connect power to MADRIX LUNA.
Connect MADRIX LUNA to your computer via USB.
[Use the provided USB cable.]
Make sure to check the power management options of Windows. Learn more »PC Power Management
2] Fixture Configuration In MADRIX
Start MADRIX.
3] Enabling Drivers In MADRIX
Go to Preferences > Options... > Devices USB
Activate MADRIX LUNA
Click Apply
Close the window with OK
Devices (USB/PCI)
4] Activating Devices
Your LUNA devices and all of their ports [4/8/16 output ports, 1 input port] will appear in the list.
If your devices are not in the list, click
[In the screenshot below, one LUNA 8 is connected.]
By default, all output ports are activated [State On].
If your device and ports are not activated, do the following:
Select the device/port in the list.
Activate Enable
Activate Output
Click Apply
5] Configuration Of DMX Output
Set up Universe
By default, DMX universe 1 - 4/8/16 are assigned to the ports DMX 1 - 4/8/16 when using one MADRIX LUNA.
Click Apply
6] Frame Time
Click Apply
[When using USB, the Frame Time (ms) will be automatically set to the same value for all output ports.]
7] Optimized Frames Or Full Frames
- Activating Send Full Frames is recommended if problems with the data output of your devices occur.
Click Apply
In addition, you can activate Send Full Frames for the device and each MADRIX LUNA output port separately.
Learn more MADRIX Device Configuration
More Information About DMX Output
Learn more »DMX512 [DMX-OUT]
You can connect MADRIX LUNA via Ethernet network to the network card of your computer that runs the MADRIX software. Data is sent into the LUNA via DMX-IN [XLR] and from the LUNA to MADRIX via Ethernet network.
Connect your external DMX controller to the DMX-IN port of MADRIX LUNA.
Connect MADRIX LUNA to your computer via network cabling.
Art-Net is a network-based protocol. MADRIX will use the network card of your computer to receive data.
- 255.0.0.0
3] Activating Art-Net
Activate Enable
4] Configuration Of Art-Net Remote
Select ArtNet Remote in the list.
Click
A new window opens [Art-Net Device Configuration].
Set Universe Port OUT to 256, which is Art-Net universe 256. Confirm with Apply
[By default, MADRIX LUNA sends DMX-IN data to Art-Net universe 256. You can change these settings in the Web Configuration or MADRIX Device Configuration window if required. If you have changed the settings, enter the exact same Art-Net universe here!]
Activate Direct IP Mode and enter the IP Address of your MADRIX LUNA. Confirm with Apply
[E.g., 10.206.224.14]
[You can also activate Broadcast Mode. In this mode, MADRIX will receive any DMX data that is sent in the network on this particular Art-Net universe.]
Press OK
5] Activating Art-Net Remote
You need to activate the Art-Net Remote device. Art-Net Remote is still deactivated.
Activate Enable
Input is automatically selected.
Click Apply
If required, change the Frame Time (ms)
The higher the Frame Time, the lower the FPS will be. The lower the Frame Time, the higher the FPS will be.
The default Frame Time is 33.
Press Apply to confirm.
6] Activating DMX Input
Go to Preferences > Device Manager... > DMX Input
DMX Input Tab
Select your preferred DMX Universe in the list.
[By default, DMX universe 1 to 8 are listed. If you wish to increase the number of DMX-IN universes, you can change the setting. Learn more »Performance]
Choose your DMX-IN Device in the section Device. Select ArtNet Remote
Art-Net Remote is now activated. MADRIX can already receive DMX data.
Now, choose how to use incoming data. Learn more »Art-Net Remote
DMX-IN Via USB
You can connect the LUNA directly via USB to the computer that runs the MADRIX software. Data is sent into the MADRIX LUNA via DMX-IN [XLR] and from the LUNA to MADRIX via USB.
[Use the provided USB cable]
2] Enabling Drivers In MADRIX
Click Apply
Devices (USB/PCI)
3] Activating Devices
Select MADRIX LUNA DMX-IN in the list.
Activate Enable
Click Apply
DMX Input Tab
Choose your DMX-IN Device in the section Device. Select MADRIX LUNA - DMX-IN
DMX-IN is now activated. MADRIX can already receive DMX data.
Now, choose how to use incoming data. Learn more »DMX-IN
In order to use these features, please Enable ArtAddress first.
[Please make sure that your nodes fully support this Art-Net feature, such as MADRIX LUNA, MADRIX NEBULA, MADRIX PLEXUS, MADRIX STELLA. You will also get notified by a message box. Confirm the message with OK or abort via Cancel.]
Highlight Device Button
Mute Status Indicators - Switches off and disables all built-in status indicators of a device over Art-Net [ArtAddress > AcLedMute].
Operate Status LEDs Normally - Allows the built-in status indicators of a device to operate normally again, after having them switched off [ArtAddress > AcLedNormal].
Highlight Device - Activates the highlight mode [ArtAddress > AcLedLocate]. Select one or more interfaces and click the button. The corresponding status indicators of the selected interfaces will flash for a better identification or tests. This makes it easier to see them on site/stage. It considerably speeds up the procedure of programming or testing the selected interfaces.
DMX Watcher
DMX Watcher
Watch Universe
Watch Universe - Appears when you have selected a list item. The DMX Watcher will open with the particular DMX Universe already entered.
Learn more »Tools
MADRIX LUNA features automatic HTP merging from 2 Art-Net sources.
[Usually, the first source will be MADRIX. The second source could be a console, for example.]
Data from both source will be merged together and sent out as 1 signal. This happens across all 8 output ports and by using the HTP principle.
HTP - Is the acronym for Highest Takes Precedence. Data from both sources will be compared for each individual channel. The higher value wins per channel.
Example: We are using an LED fixture with a total of 5 control channels [3 color channels and 2 movement channels]. MADRIX should provide the color data for channels 1 to 3 and the console should provide the movement data for channels 4 and 5. Using the MADRIX Fixture Editor, we could create a corresponding fixture where channel 4 and 5 are set up as Fixed channel using always a value of 0. On the other hand, the console will always send a value of 0 for the first 3 channels of each fixture. This will ensure that the data from the console will always provide the higher value on channels 4 and 5, while MADRIX provides the color data. Due to the automatic HTP merging of the device, the LED fixture will receive correct data from both sources as desired.
Configuration And Recommendations
1] Correctly set up and enable Art-Net for each source.
2] Make sure to activate Sync Mode for Art-Net in MADRIX. Learn more Sync Mode
3] Make sure that MADRIX has a lower IP address compared to the second source.
[E.g., 2.0.0.1 compared to 2.0.0.20]
4] Always use Direct IP Mode to directly send data to the correct IP addresses of your MADRIX LUNA devices.
[It is not recommend to have any of the two sources or any other source in the network to send data via Broadcast Mode.]
Reset Via Reset Button
Disconnect MADRIX LUNA from power.
Use a suitable tool to press the reset button on the unit’s back side.
Continue to press the reset button and connect to power again.
Continue to press the reset button and wait until all status LEDs on the front of the device flash repeatedly or wait 10 seconds.
Reset Via USB [MADRIX LUNA Updater]
Close the MADRIX software.
Start the separate MADRIX LUNA Updater tool.
[In Windows, go to Start > All Programs > MADRIX 3 > Tools > MADRIX LUNA Updater]
In the MADRIX LUNA Updater, click Reset To Factory Default Settings
Wait for the reset process to end [usually it takes only seconds].
Learn more MADRIX LUNA Updater
Firmware Updates
Update Via USB
Start the MADRIX software.
Open the MADRIX Device Configuration window. Go to Tools > MADRIX Device Configuration...
Click to search for connected devices and your device will appear in the list.
Select your device in the list and click Firmware
Wait for the process to end [usually it takes only seconds].
Disconnect MADRIX LUNA from power and connect again.
[You can also use the MADRIX LUNA Updater. Learn more MADRIX LUNA Updater]
Update Via Ethernet
Connect MADRIX LUNA to your computer via Ethernet network.
In MADRIX, go to Preferences > Device Manager... > Art-Net
Activate Art-Net
Click
Learn more DMX-OUT Via Ethernet Network [Art-Net]
Select the device in the list. Click . A new window opens.
Click Firmware
The update process will starts.
The MADRIX logo on the front of the device will start to flash and the firmware will be updated.
LED Status Codes
The following tables describe the LED status codes on the front of the device.
STATUS
POWER
Powered off
Power cable not connected.
The device has no power.
Permanently green
Connected to power.
The power is on.
STATUS
ETHERNET
Powered off
Ethernet not connected
or the device has no power.
USB not connected
Permanently green
Connected to Ethernet.
No data is sent or received over Ethernet.
Connected to USB.
No data is sent or received over USB.
Blinking green
Communicating over Ethernet.
Sending or receiving data over Ethernet.
Communicating over USB.
Sending or receiving data over USB.
STATUS
DMX-IN
DMX-OUT
Powered off
DMX not connected
DMX not connected
Blinking green
Receiving data via DMX-IN.
The device works correctly.
Sending data to DMX OUT.
Web Configuration
When connected to Ethernet network, you can easily configure MADRIX LUNA using a web configuration interface.
You have 2 options to access the web interface:
A] Open your web browser and enter the IP address of MADRIX LUNA.
[Both, LUNA and your computer, need to be in the same network.]
B] Use MADRIX.
Select your MADRIX LUNA device in the list.
Click
Your default web browser will open.
Now, you have access to various information and settings.
Device Name
You can change the description of the device. Enter a name and confirm your input with Set. This label is only shown in this web interface.
Device Settings
You can change the IP address and Subnet Mask. Enter the specific addresses and confirm with Set.
DMX Output Settings
This section shows specific settings for the DMX output ports [DMX 1 - 4/8/16].
By default, Art-Net universe 1 - 4/8/16 are assigned to DMX 1 - 4/8/16. [This is the recommended setting when using one MADRIX LUNA].
If you are broadcasting data for a large number of Universes [using Broadcast Mode instead of using Direct IP Mode] with MADRIX or a 3rd-party controller for example, you can assign different DMX universes to each LUNA device with these settings. Each MADRIX LUNA will then only receive data from the specific Art-Net universe and send it to its specified output port. Example: You can set up that LUNA 8 #1 only listens to Art-Net universe 1 - 8, while LUNA 8 #2 listens to Art-Net universe 9 - 16, and LUNA 8 #3 listens to Art-Net universe 17 - 24, and so on.
Send Always Full Frames (512 CH) - Is another specific setting. The XLR DMX output port will always send out 512 channels, even if the data sent to LUNA includes less than 512 channels for this port and universe. LUNA automatically sends values of 0 on channels that are not used.
In Case Of Data Connection Loss - Is only available in the web configuration tool. Allows you to specify the output settings of the LUNA should the device not receive data anymore for a specified DMX universe. Choose from the following options:
Send The Last Received Frame Continually
Send Black Frames Continually
Stop Sending After Sending A Black Frame
Stop Sending
DMX Input Settings
This section allows you to specify settings for DMX input.
When data is received through the DMX-IN port, MADRIX LUNA will automatically forward it to Ethernet network.
LUNA can receive 512 channels via the DMX-IN port. Use Send To Art-Net Universe to specify on which Art-Net universe those 512 channels are sent. By default, 256 is selected. Valid values range from 1 to 256.
Send Always Full Frames (512 CH) To Art-Net - Is another specific setting. The XLR DMX input port will always send out 512 channels, even if the data sent to LUNA includes less than 512 channels for this port and universe. LUNA automatically sends values of 0 on channels that are not used.
Additionally, choose to how MADRIX LUNA sends the data into the network:
Use Broadcast Mode if LUNA should sent to all IP addresses in the network.
Use Direct IP Mode to specify one recipient, e.g. your MADRIX computer [Enter the IP address of your MADRIX computer].
Confirm with Set
Device Information
This section displays various details about the device, including:
Model [Device type]
IP Address [Current IP address]
MAC Address [A permanent, unique address]
Serial Number
Firmware [Current firmware version]
Bootloader [Current bootloader version]
Hardware [Hardware revision/model]
You can access the information and settings of the web configuration in MADRIX using the MADRIX Device Configuration window.
In MADRIX, go to Tools > MADRIX Device Configuration...
[Keyboard shortcut: Ctrl+Alt+L]
MADRIX LUNA Configuration
Scans the USB ports of your computer and the network for connected MADRIX LUNA devices. If devices are found, they will be shown in the list.
- To see USB devices, you need to enable LUNA USB drivers first [they are activated by default]. Learn more »Devices USB
- To see network devices, you need to enable LUNA networking drivers [they are activated by default] and connect MADRIX LUNA and your computer to the same network first. Learn more »Devices Network
Refreshes already connected devices and brings the information in the list up to date.
Allows you to change the settings of your device. Apply your changes by confirming with Set
Enables remote access to the web configuration as explained above. MADRIX LUNA needs to be connected via Ethernet [network connection required]. First, connect your computer and the MADRIX LUNA to one and the same network. Second, select your MADRIX LUNA in the list. Third, click this button. A web browser opens automatically.
Imports the MADRIX LUNA Device Settings from an external file [of the file type *.mldx]. Use this option to easily restore all device settings from a file [as described below].
Exports the MADRIX LUNA Device Settings to an external file [of the file type *.mldx]. Use this option to easily store all device settings in a file. Simply enter a name in the window that opens and click 'Save'.
Updates the firmware of your MADRIX LUNA if a newer firmware is available [USB connection required].
Learn more Web Configuration
MADRIX LUNA Updater
MADRIX LUNA Updater is a separate tool only for MADRIX LUNA.
Usage
MADRIX LUNA Updater
MADRIX LUNA Updater can be used for several, specific tasks.
Updates the firmware of all LUNA devices that are connected to the computer via USB. First, select the correct firmware in the list above this button [Example: LUNA 1.0.000 Type V1.0 MADRIX 3.0]. Second, click the button. Third, disconnect the power after updating in order to restart the device.
Resets all settings of all LUNA devices that are connected to the computer via USB to the standard values. Use this function to restore the original settings of the device.
Additional information on the status of the performed functions will be given on the right side of the window. Information is displayed from down to top [the latest information is shown at the top].
Available Firmware Updates
LUNA Firmware
MADRIX Version
Release Date
Highlights
1.00.4547
MADRIX 3.0
July 2013
Initial Release
1.01.4555
MADRIX 3.1
November 2013
Improved functionality and communication with the MADRIX Software.
1.02.4946
MADRIX 3.2
March 2014
Added support for LUNA 4 and LUNA 16 in addition to LUNA 8.
1.03.5043
MADRIX 3.3
November 2014
Optimized device reply time (Poll Reply) to ensure that all connected devices are found when searching for them automatically in MADRIX.
Fixed an issue that would reset the network settings with the next start when a Subnet Mask higher than 255.255.255.0 was set up.
Fixed issues with sending out data when receiving Art-Net data from two sources.
Fixed an issue that only used the last of DMX output ports to send out data when several ports had been assigned the same Art-Net universe.
1.04.5298
MADRIX 3.3a
December 2014
Fixed an issue that the IP address could not be changed using the web configuration tool.
1.05.5501
MADRIX 3.4
June 2015
Fixed that the Poll Reply only returned 4 ports for LUNA 8 or LUNA 16.
1.05.5997
MADRIX 3.6
May 2016
All built-in status LEDs can now be switched off over Art-Net via ArtAdress.
1.05.6298
MADRIX 3.6b
September 2016
Web configuration tool: Added the Refresh button to always show the latest information that was last saved on the device in the web browser (instead of using a browser refresh which may change settings again).
1.05.6996
MADRIX 3.6d
December 2016
Fixed an issue for LUNA 4 that returned an incorrect BindIndex after receiving a PollReply.
1.06.7074
MADRIX 3.6h
February 2018
Added 4 distinct options for sending data output in case of data connection loss [only available in the web configuration tool]:
- Send The Last Received Frame Continually
- Send Black Frames Continually
- Stop Sending After Sending A Black Frame
- Stop Sending
Increased the minimum output frequency that is sent on each port from 10 FPS to 20 FPS [in order to ensure functionality with lighting fixtures that are not working correctly when receiving low frame rates].
1.06.7106
MADRIX 3.6i
June 2018
Added BindIdx 3 to the PollReply to better communicate the additional DMX-IN port in MADRIX 5.
Web configuration page: Art-Net universes are now also shown in hexadecimal notation in addition to the decimal notation.
1.06.7172
September 2019
Web configuration page: Fixed a critical issue that discarded the current setting for In Case Of Data Connection Loss when disconnected from power and automatically reset to the default value again.
Fixed a critical issue that could halt the device in rare cases.
If new drivers and a new firmware are available for the MADRIX LUNA, please always update the firmware first and then the drivers!
MADRIX LUNA Updater does not work when MADRIX is running. Please close MADRIX and restart MADRIX LUNA Updater.
Where To Find The MADRIX LUNA Updater
The MADRIX LUNA Updater is included in the MADRIX Installer. After installing MADRIX, you can find a link to the MADRIX LUNA Updater in the Windows Start menu:
The original, executable program can be found in the MADRIX installation directory:
C:\Program Files (x86)\MADRIX3
