Web Configuration
You Are Here:  »You Have Selected A Parent Chapter«
Web Configuration
When connected to Ethernet network, you can easily configure MADRIX AURA using the built-in web configuration.
How To Access
You have 2 options to access the web interface. Both, MADRIX AURA and your computer, need to be in the same network.
A] Using a standard web browser:
▪Connect MADRIX AURA and your computer to the same network.
▪Assign correct network settings for your PC in the Windows operating system.
[Recommended default settings: IP address 10.0.0.1 / Subnet mask 255.0.0.0]
[Please note: Your devices and the sender, such as the PC that runs MADRIX 5, need to have the same subnet mask!]
▪Open your web browser and enter the IP address of MADRIX AURA.
[You can find the default IP address on the right side of the device.]
▪The built-in web configuration will be launched. You will have access to various information and settings.
B] Using the MADRIX 5 Software:
▪Go to the menu Tools > MADRIX Device Configuration...
[Keyboard shortcut: Ctrl+Alt+L]
▪Select your MADRIX AURA device in the list.
▪Click
▪Your default web browser will open and the web configuration will be launched. You will have access to various information and settings.
Topics Of This Chapter
The following sections are explained in this chapter:
MADRIX AURA User Manual 4.01.
