Recording – Network Recording Settings
The Recording section defines how incoming data is received over Ethernet network for recording.
▪Make sure to confirm any changes with Set
Port
Lists the available ports of your device.
▪MADRIX AURA 2 offers 2 universes.
▪MADRIX AURA 8 offers 8 universes.
▪MADRIX AURA 12 offers 12 universes.
▪MADRIX AURA 32 offers 32 universes.
All - Sets the corresponding setting for all ports.
Automatically numbers all universes based on the first port [ascending order].
Automatically numbers all universes based on the first port [descending order].
State
Defines the current status of each port.
On - Enables the port.
Off - Disables the port.
Protocol
Defines the communication standard over Ethernet network.
Art-Net - Activates that Art-Net data is recorded.
sACN - Activates that Streaming ACN data is recorded.
Universe
Defines which universe is recorded for the specific port.
▪By default, ports 1 - 2 are assigned to universes 1 - 2 for MADRIX AURA 2.
▪By default, ports 1 - 8 are assigned to universes 1 - 8 for MADRIX AURA 8.
▪By default, ports 1 - 12 are assigned to universes 1 - 12 for MADRIX AURA 12.
▪By default, ports 1 - 32 are assigned to universes 1 - 32 for MADRIX AURA 32.
▪ Automatically numbers all universes based on the first port [ascending order].
[Enter the start universe for port 1, click the button and all other ports will be numbered consecutively.]
▪ Automatically numbers all universes based on the first port [descending order].
▪You can use the tooltips by hovering with your mouse over the number to double-check the assignment of the universe:
▪Attention: Please note the fundamental change in the assignment of Art-Net universes with firmware version 4.00! See »Firmware Updates
Watcher
Allows you to monitor the data for the individual port in the DMX Watcher [see »DMX Watcher].
MADRIX AURA User Manual 4.01.
