Scenes – Scene Files
The Scenes section shows all available scenes and their individual details.
MADRIX AURA can manage a maximum of 1000 Scenes.
Default Scenes
Before delivery, a number of stock scenes has been upload to the SD card of your device.
You can download them again here:
https://www.madrix.com/download/aura/MADRIX_AURA_Default_Scenes.zip
Scene File List
Control Buttons
Shows the page that is currently selected.
Allows you to download the currently selected Scene File. Learn more below
Allows you to upload new files. Learn more below
Deletes the currently selected file from the SD card.
Deletes all files from the SD card.
Shows that the SD card is write-protected [locked] or that no SD card is inserted into the device.
Attention:
▪ If you delete a file here that is linked to the cue list, any scene in the cue list that uses this file will not properly work anymore, because the file will not be selected as source [Scene File] anymore.
File Name
Shows all scenes that are saved on the currently inserted SD card in a list.
Linked Files
Shows that the specific file is linked and currently used in the cue list.
Empty - Shows that the file is currently not used in the cue list.
Scene File Details
Select a scene on the left side in order to see its properties on the right side.
File Name
Shows the name of the currently selected scene. And allows you to change the name of the scene file.
Attention:
▪ If you rename a file here that is linked to the cue list, any scene in the cue list that uses this file will not properly work anymore, because the file will not be selected as source [Scene File] anymore and be left empty. [If you rename a new file with the exact name of the old file again, the cue list will automatically reference the new file.]
▪The following characters are allowed for custom file names:
a-z
A-Z
0-9
. [Dot]
_ [Underscore]
- [Minus]
( [Opening Round Bracket]
) [Closing Round Bracket]
# [Number Sign, Hash]
{ [Opening Curly Bracket]
} [Closing Curly Bracket]
[Space] [Spaces are also allowed but not as the first character.]
▪Make sure to add .dxd at the end of the file name!
File Size
Shows the size of the currently selected scene on the SD card [in byte].
File Time
Shows the currently assigned timestamp of the currently selected scene.
File Creation
Shows when the file of the currently selected scene was created originally.
Name
Shows the label of the currently selected scene.
Author
Shows the label of the file creator. This can be customized in the Device Settings.
Generator
Shows the process or instance that created the currently selected scene, such as the device itself.
Data Length
Shows the precise size of the currently selected scene; independently of the file system [in byte].
Data Version
Shows the version number of the recording process with which the file was created.
Data Format
Shows if the file was created for MADRIX AURA 2 [2 Universes], MADRIX AURA 8 [8 Universes], MADRIX AURA 12 [12 Universes], or MADRIX AURA 32 [32 Universes].
Play Duration
Shows the duration and playback length of the currently selected scene in HH:MM:SS.MS [Hours:Minutes:Seconds.Milliseconds].
Upload And Download
You can upload and download files directly via the web configuration, and thus your web browser.
Download
1] First, select the Scene you would like to download.
2] Second, click this Download button.
3] Third, the file will be downloaded by your web browser [to the default Download location of your web browser].
Upload
Click on this Upload button and a new site will be shown in the web configuration.
Takes you back to Scene Files [menu Scenes].
Supported File Formats
*.dxd - Is the file format of MADRIX AURA Scene Files.
*.xml - Is the file format of the Show Configuration file, the file that includes the settings of the MADRIX AURA Cue List and Timers. [This is also the file format of the Network Configuration file. Learn more about these files here.]
Existing Files
Choose how to manage files that are already saved on the SD card with the same name.
The options are:
Replace - Files that already exist will be replaced with the files that you will be uploading.
Rename - Files that already exist will remain as they are and files that you will be uploading will be renamed. [Example: ShowConfig.xml – File already exists and will be renamed to NewShowConfig.xml.]
Skip - Files that already exist will remain as they are and files that you will be uploading will be skipped and not uploaded.
File Selection
Browse... - Click in order to select the files from your storage location/computer/storage devices.
You can select multiple files.
Files up to a file size of 4 GiB are supported.
Progress
Shows a progress bar to indicate the estimated progression of the upload process.
Aborts any upload process that has been started.
Starts the upload process.
First, make sure to click Browse... to select your files and choose how to manage Existing Files.
A summary of the upload progress will be provided after all files have been uploaded.
Takes you back to Upload.
Workflows
The direct upload and download in the web browser, for example, allows you to:
▪Upload new Scene Files and afterwards to add them to the Cue List and configure those cues as needed.
▪Download a backup copy of all current Scene Files and the accompanying Show Configuration; before making any new changes.
Should the new changes be unfavorable, you can upload the backup copy again to restore the previous state.
▪Download all current Scene Files and the accompanying Show Configuration from a device that seems faulty or shows incorrect behavior to a replacement unit.
▪Offer programming services to a client of yours by adding to an existing show or playlist or create new Scenes and a new Cue List for the client on your device first, and finally upload them to their device in an easy way.
▪Use a PC/computer/laptop that is not using the Windows operating system [which is required to run the MADRIX HARDWARE MANAGER Software], but instead  using a normal web browser on such a machine for the upload of files.
▪Avoid having to use the MADRIX HARDWARE MANAGER on a dedicated remote PC/computer/laptop over a VPN connection to supply new files to devices; now the connection over VPN and a normal web browser is enough.
MADRIX AURA User Manual 4.01.
