Control – Live Control
The Control section allows you to directly control the status of the device.
Operating Panel
Sync. Type
The panel shows if the device has been set as a Master or Slave device.
Control Buttons
These include Skip To Previous Cue, Record, Stop, Pause, Play, and Skip To Next Cue.
Attention:
▪Make sure to send control data to the device before you start a recording process [Art-Net or Streaming ACN]!
▪You will see a status message, when the inserted memory card is not ready for recording [No SD Card, SD Card Full, SD Card Protected].
▪Make sure that MADRIX AURA is the only sender in the network when playing back scenes.
[You will run into issues if the original sender from which the device recorded its data from is still sending to the same universes.]
▪Based on the FAT32 file system, files on the SD card can only have a maximum file size of 4 GB. Should a recording process create such large files, MADRIX AURA automatically creates new files and continues recording, and adds a second index number to the file names in addition to the original index.
▪Recorded data that is saved on the SD card will be encrypted first.
Cue :
Shows the index number and name of the current cue.
Time :
Shows the duration of the cue in HH:MM:SS [Hours:Minutes:Seconds].
Loop :
Shows the current loop number [as you can set cues to repeat and play several times in the Cue List Editor].
XY % / 00:00:00
Shows the current position of playback [in %] or recording [in HH:MM:SS]. A green visual indicator acts as a progress bar.
Playing - Indicates that a cue list is being played back.
Paused - Indicates that playback has been halted.
Stopped - Indicates that playback has been stopped.
Fading - Indicates that the scene includes a fade-in time as set in the Cue List Editor.
Starting - Indicates that the playback starts soon.
Recording - Indicates that a recording process is currently active.
Recording (Awaiting Data) - Indicates that a recording process has been started, but that the device is currently not receiving any incoming data it could record.
If your Cue List uses a Fade Type and Fade-In Time, the visual indicator/progress bar will indicate that by pushing outgoing Scenes visually down, while the new Scene comes in at the top.
Output Panel
▪Use a left mouse double-click to reset to the default value.
Intensity
Sets the main brightness of the output.
Valid values range from 0 to 255 [in the DMX range] or from 0 % to 100 % [in percent] depending on your device settings. The default value is 255.
Speed
Sets the general playback speed of the device.
[This speed is multiplied by the speed of a Cue in the Cue List; for a total maximum speed of 400 %.]
Valid values range from 1 % to 200 %. The default value is 100 %.
Intensity Group Panel
▪Intensity Groups refer to the Channel Mask. Learn more »Channel Mask
Faders
Allow you to control the intensity of Intensity Group 1 to 8 with the help of the mouse.
Input Fields
Allow you to control the intensity of Intensity Group 1 to 8 with the help of direct value input via the keyboard or up and down buttons.
Valid values range from 0 to 255 [in the DMX range] or from 0 % to 100 % [in percent] depending on your settings. The default value is 255.
MADRIX AURA User Manual 4.01.
