Devices Network
Further Configuration
MADRIX 5 allows to activate or deactivate drivers or network communication protocols for various products.
Go to the menu Preferences > Options... > Devices Network
Devices Network
Activate the required drivers.
[When activated, MADRIX 5 automatically searches for supported devices at startup.]
You can enable the followingnetwork drivers here:
Philips Color Kinetics - KiNET
inoage - MADRIX
[For MADRIX AURA, MADRIX LUNA, MADRIX NEBULA, MADRIX PLEXUS, MADRIX STELLA, and MADRIX ORION]
MA Lighting - MA-Net
CAST Software - BlackTrax - RTTrPM
ESTA - Streaming ACN
Capture - CITP
Philips - Hue
When activating a driver, please always make sure that you have selected the correct network card.
Further configuration is needed:
Devices Network only activates the required drivers and often the corresponding network card.
Make sure to configure your hardware interfaces also according to your requirements.
Learn more
»Philips Color Kinetics [KiNET]
»MADRIX AURA
»MADRIX LUNA
»MADRIX NEBULA
»MADRIX PLEXUS
»MADRIX STELLA
»MADRIX ORION
»MA Lighting MA-Net
»CAST Software BlackTrax
»ESTA Streaming ACN [sACN / E1.31]
»CITP
»Philips Hue
Only activate the drivers you require. In this way, you can speed up the loading/starting time of MADRIX 5.
All options of Devices Network will be saved locally on your computer. The settings described in this topic will not be saved in your MADRIX 5 Setup file.
