MADRIX NEBULA
You Are Here:  MADRIX Hardware >
MADRIX NEBULA
MADRIX NEBULA is a versatile interface to directly control a wide range of digital LEDs.
The MADRIX NEBULA directly connects to your LED pixels. This advanced SPI decoder receives control data over Ethernet network or USB and is built to provide excellent image quality.
Using A 3rd-Party Controller
MADRIX NEBULA is a standard network node. Because of this, you can use the device with applications, consoles, desks, or controllers that are compatible with Art-Net or Streaming ACN [sACN] to distribute data via Ethernet network.
MADRIX NEBULA works great with MADRIX 5.
More Information
MADRIX NEBULA offers a lot features. Because of this, a separate, complete guide is available. You can find the majority of information about the MADRIX NEBULA in the
MADRIX NEBULA Technical Manual & Quick Start Guide
Download it from »help.madrix.com
MADRIX NEBULA User Manual
MADRIX 5.7.
