Philips hue |
Topics of this chapter: ▪Note
The MADRIX 5 Software natively supports Philips Hue.
The MADRIX 5 Software requires that Hue bridges/products use at least API version 1.15.
The following lamps are currently supported: ▪LCT ▪LDD ▪LDF ▪LDT ▪LFF ▪LLC ▪LLM ▪LST ▪LTC ▪LTD ▪LTF ▪LTP ▪LTT ▪LTW ▪LWB ▪MWM ▪Multisource Luminaires - Using The Color Light Module (LLM001) ▪Multisource Luminaires - Using The Color Temperature Module (LLM010/LLM011/LLM012)
The following gamuts are currently supported: ▪COLOR_GAMUT_NONE ▪COLOR_GAMUT_A ▪COLOR_GAMUT_B ▪COLOR_GAMUT_C ▪COLOR_GAMUT_2200K_6500K
There are several steps required to set up Philips Hue products in MADRIX 5. This chapter is only part of the process. You need to set up other configurations as well [such as virtual LED matrix, DMX Devices, MADRIX Effects, Audio, etc.].
1] Set up the correct network settings in Windows. 2] Enable drivers in MADRIX 5. 3] Authorize a bridge. 4] Set up the DMX universe. 5] Set up the Frame Time.
1] Network Settings Philips Hue is a network-based protocol. MADRIX 5 will use the network card of your computer to send data to the bridges. ▪Connect the computer that runs the MADRIX 5 Software and your Philips Hue bridges with the same computer network. ▪To use Philips Hue, you need to have a separate DHCP server. ▪This can be a software or hardware DHCP server, which handles and assigns the IP addresses to the Hue bridges and to the MADRIX computer. ▪It is recommended that the DHCP server binds MAC addresses to IP addresses.
2] Enabling Drivers In MADRIX 5 ▪Go to the menu Preferences > Options... > Devices Network ▪Activate Philips - Hue
▪Time To Detect Bridges And Lamps (s) - Defines how long MADRIX 5 searches the network for devices during startup. Type in a value in seconds.
3] Authorize A Bridge ▪Go to the menu Preferences > Device Manager... > DMX Devices ▪MADRIX 5 automatically adds network devices it has found during startup to the list. ▪Click if the devices have not been found.
▪Select your device in the list. ▪Right Mouse Click on the column State to set from Off to On [indicated by green light]. 1] When connecting a hue bridge to MADRIX 5 for the first time, you need to authorize the bridge first. MADRIX 5 will ask you to authorize it: 2] In order to authorize the bridge, press the large Link button on the bridge itself. 3] Click OK in MADRIX 5 in order to confirm that you have pressed the button on the bridge. 4] The authorization process starts. MADRIX 5 will wait up to 30 seconds for the device to respond. 5A] When unsuccessful, MADRIX 5 will provide an error message that the authorization process failed. If that is the case, please try to authorize it again. 5B] When successful, the bridge will be authorized and enabled in MADRIX 5.
▪If you wish to deactivate a bridge, select it in the Device Manager > DMX Devices and set its State from On to Off
5] DMX Universe ▪Make sure that your device is still selected. ▪Set up Universe ▪This setting assigns a specific DMX universe [of the Patch] to the device or the port of the device. Learn more »Virtual DMX Universes ▪Make sure to assign the correct universe according to your requirements.
6] Frame Time ▪Make sure that your device is still selected. ▪Set up the frame time for your device.
DMX Devices Learn more about setting up devices under Preferences > Device Manager... > DMX Devices here »DMX512 [DMX-OUT]
Remember to configure your virtual LED matrix in the »Matrix Generator or »Patch Editor Make sure to save your MADRIX 5 Setup after the configuration process.
▪Keep in mind that network devices, if activated, cause network traffic! ▪When using a network-based output protocol and when the Startup option Start MADRIX After Booting Windows is used, it is highly recommended to also activate the Startup option Start With Timeout(s) with a value of 30 or higher.
▪A hue bridge often has several status LEDs. Please consult the hue manuals for more information. In general, they usually show these statuses: ▪You can use the official Philips hue mobile App to update the firmware of your Philips hue bridges. ▪MADRIX 5.4 adds compatibility for firmware version 1.40.
MADRIX 5.6. |
