Controls [Deck A / Deck B]
  Previous  Next
Next to Preview Deck A and next to Preview Deck B you will find different controls that affect the outcome of the entire Deck A or Deck B. They are available to you per side, as explained below.
Submaster Deck A/Deck B
Submaster - Controls the intensity of the entire Deck A or Deck B.
It will affect the visual outcome on the left or right side, independently of which Storage, Storage Place, or Layer is selected.
Left Mouse Click And Hold - Select the required value by moving the fader with the help of your mouse. Release the mouse button to set up the specific value [The fader will disappear automatically].
A value of 255 means full intensity.
A value of 0 means no intensity and will render the effect completely black. A value of 0 is shown in red in order to make its severe affect on the visual outcome clear. The button itself pulsates in red as well.
The tooltip shows the currently set value.
Color Filter Deck A/Deck B
Color Filter - Filters the colors of the entire Deck A or Deck B.
Left Mouse Click And Hold - Select the color using the Color Picker to activate the Color Filter.
- You can also use Global Colors. Learn more »[Global] Colors And Intensity
Right Mouse Click - Calls up the context menu.
Edit... - Calls up the Color Fader Box.
Make Local - Converts a Global Color to a Local Color. Learn more »[Global] Colors And Intensity
Make Global - Converts a Local Color to a Global Color. Learn more »[Global] Colors And Intensity
Update Globally - Allows you to change a modified Global Color everywhere by updating it globally. Learn more »[Global] Colors And Intensity
Global Selection - Allows you to choose a Global Color as this color. Learn more »[Global] Colors And Intensity
Choose from the following modes:
Allow Through - Lets only the color that is chosen through and filters every other color out.
Filter Out - Removes the color that is chosen and lets all other colors through.
Colorize - Applies the chosen color as tint color.
Ignore - Allows you to quickly deactivate the filter, especially when controlling it remotely via a lighting console [instead of needing to set it to Allow Through with color White].
Defaults - Restores the default color. The default value is Allow Through with color White, which means that no filter is active.
Filter [FX] Deck A/Deck B
Filters FX - Special filters can be applied to an entire Effect Pipeline Deck A or Deck B to quickly change your visuals.
Learn more »Filters [FX]
Speed Master Deck A/Deck B
Speedmaster
Speed Master Deck A/Deck B - Allows you to speed up or slow down effects.
Each Speed Master influences the speed of the entire Deck A or Deck B.
The Speed Masters work as a multiplier of the current speed of an effect [that includes the BPM of a Layer, the Pitch of a Layer, and the Pitch of a Storage Place.]
Example: A Speed Master of 2.0 will double the current speed.
How To Use
Move the fader upwards to increase the speed.
Move the fader downwards to decrease the speed.
The default value is 1.0 [which is normal speed].
A value of 0.0 will stop the effects.
The highest value is +10.
The lowest value is -10.
Negative values will reverse the direction of effects [if possible].
Double-click or right-click on the Speed Master button to reset to the value of 1.0
Pause
Pause Button
Pause - Will halt the effect.
Left Mouse Click And Hold - Pauses the effect as long as you hold the mouse button [temporarily].
Left Mouse Double-Click - Pauses the effects permanently. A single click deactivates the permanent stop again.
Options
You can define the value range of the Speed Masters in the Options.
Learn more »User Interface
MADRIX 5.6.
 Previous   Next
