▪Introduction
▪Overview
The About window provides a quick overview over software details, licensing information, and legal information.
▪Go to the menu Help > About...
Software
Software
Version
Shows which software version you are currently running and using. It also shows the used software architecture: MADRIX RADAR is 64-bit only.
Build
Shows an internal reference number.
ESTA Manufacturer List Version
Shows which version of the provided ESTA Manufacturer List the software is currently using.
Legal Copyright
© inoage GmbH. See »Imprint And Copyright
End-User License Agreement
Opens this user guide, which includes the End-User License Agreement. See »End-User License Agreement [EULA]
Third Parties
OpenSSL
License - Shows the license under which OpenSSL is used.
Qt
About Qt - Shows more information about the Qt development framework.
License - Shows the license under which Qt is used.
Qwt
License - Shows the license under which Qwt is used.
Sourcetree
Is a Git client program used for development with thanks. Powered by Atlassian.
License Overview
Licensed Devices And Features
This overview shows in great detail which licenses are currently active and which features are therefore available to you.
Refers to all MADRIX RADAR licenses:
demo - Refers to the demo mode of the software.
fragment - Refers to the MADRIX RADAR fragment License.
core - Refers to the MADRIX RADAR core License.
MADRIX Nodes - Refers to MADRIX RDM Nodes, such as MADRIX STELLA or MADRIX STELLA 8. [MADRIX 5 Software is also recognized in this way].
fusion - Refers to the MADRIX RADAR fusion License.
big data - Refers to the MADRIX RADAR big data License.
Active
Shows if a license is currently active [✓] or not [✗].
Parameters
Snapshots
Sensors
Status Messages
Event Monitoring
For each license, shows if a feature or feature set is unlocked by the corresponding MADRIX RADAR license.
Learn more about each license »License Model
Parameters - Refers to being able to Set or Get parameters from RDM devices. »Parameters
Snapshots - Refers to being able to create and load Snapshots. »Snapshots
Sensors - Refers to having access to sensor values the RDM devices report. »Sensors
Status Messages - Refers to having access to status messages from RDM devices. »Status Messages
Event Monitoring - Refers to having access to Events and Event Notifications. »Events »Event Notifications
History - Refers to the MADRIX RADAR big data License granting access to past data of sensors, status messages, and events; and not only the currently read values.
RDM Devices [Bottom Row]
For each license, shows the number of licensed RDM devices out of the total number of connected RDM devices [for example, 64/142: 64 RDM devices are currently unlocked by a MADRIX RADAR fusion small license out of a total of 142 connected RDM devices.]
All - Shows that the license [fragment, core, or big data] currently unlocks its features for all connected RDM devices [as the license is active if this is the case].
None - Shows that the license [fragment, core, or big data] currently unlocks its features for none of the connected RDM devices [as the license is not active if this is the case].
RDM Devices [Right Column]
For each feature set, shows the number of licensed RDM devices out of the total number of connected RDM devices [for example, 67/142: 67 RDM devices are currently unlocked for the Parameters feature set.]
License Details
MADRIX KEY Serial Number
Shows the serial number of the MADRIX KEY that holds the MADRIX RADAR fragment License.
Type
Shows fragment if the license is available.
Expiration Date
Shows the date and time in the future until the license is valid. If this deadline is reached, the license will no longer be valid.
Shows Lifetime if the license does not expire.
Note: Shows Not Available if no MADRIX RADAR fragment License has been recognized, can be found, or is available.
Shows the serial number of the MADRIX KEY that holds the MADRIX RADAR core License.
Type
Shows core if the license is available.
Expiration Date
Note: Shows Not Available if no MADRIX RADAR core License has been recognized, can be found, or is available.
Shows the serial number of the MADRIX KEY that holds the MADRIX RADAR fusion License.
Type
Shows which kind of fusion license is provided [small (64 Devices), medium (512 Devices), large (4096 Devices)].
Expiration Date
Note: Shows Not Available if no MADRIX RADAR fusion License has been recognized, can be found, or is available.
Shows the serial number of the MADRIX KEY that holds the MADRIX RADAR big data License.
Type
Shows big data if the license is available.
Expiration Date
Note: Shows Not Available if no MADRIX RADAR big data License has been recognized, can be found, or is available.
Notes
▪Please note: It is possible that a single MADRIX KEY holds both licenses, a MADRIX RADAR fusion License as well as a MADRIX RADAR big data License. If that is the case, the same MADRIX KEY serial number will be shown.
Miscellaneous
Left Mouse Click + Hold + Select / Left Mouse Double-Click / Left Mouse Triple-Click - Allows you to select text.
Right Mouse Click > Copy - Allows you to copy text in order to paste the information into an e-mail, for example.
Check For Software Updates
Checks online if a software update or new ESTA Manufacturer List is available for downloading. This requires an active internet connection.
Close
Closes the About window.
