Events
  Previous  Next
MADRIX RADAR sends and receives requests from connected RDM devices, which include valuable information, such as sensor values.
In addition to merely requesting and receiving information, MADRIX RADAR will apply its own logic in order to create events for you. By checking and validating incoming data, MADRIX RADAR provides actionable reports for you.
This functionality is not part of the RDM specification and provides great additional value when using MADRIX RADAR. As such, it is an important tool for monitoring and supervising the project.
You can choose to show events only in the software itself, or set up custom notifications according to your requirements [see the next chapter].
The Events view shows all occurred events from all RDM devices.
In general, please allow for several minutes of time to pass before events are registered and shown.
Timestamp
Shows the local time when the event occurred. [YYYY/MM/DD  HH:MM:SS]
Category
Shows the kind of event [including Info, Warning, Critical, Fatal].
Network
Shows the network IP address of the network adapter, to which the interface is connected. [TCP/IPv4] [This information refers to »Art-Net.]
Network Name
Shows the name of the network adapter.
Interface IP Address
Shows the IP address of the hardware interface to which the RDM device is connected. [This information refers to »Art-Net.]
Interface Short Name
Shows the short name of the hardware interface to which the RDM device is connected. [This information refers to »Art-Net.]
Interface Long Name
Shows the long name of the hardware interface to which the RDM device is connected. [This information refers to »Art-Net.]
DMX Universe
Shows the currently assigned DMX universe for the RDM device. [Learn more »Glossary]
Unique ID
Is also shown in the Devices view. Represents a unique identifier of the RDM device. It is shown as HEX [without 0x] and using a colon [:] as separator. The first part is the ESTA ID of the manufacturer and the second part is a number, which can be freely defined by the manufacturer.
Sub-Device ID
Shows a value of 0 if the device is a so-called root device. For all others, the sub-device ID for devices that have one is shown.
Domain
Shows to which type entry is assigned to, such as Devices.
Item
Shows a specific reference of where the event occurred if available.
Such reference could be Curve, DMX Personality, Language Capability, Lock State, Modulation Setting, Parameter, Output Response Time, Preset, Self-Test, Sensor, or Slot [and includes the corresponding item number].
Label
Shows the quick identifier of the specific event.
Description
Shows an in-depth explanation of the event for your information and as basis to act upon.
All events will be logged.
Events are stored temporarily. They are shown until the software is closed.
In addition, events referring to history data will be stored persistently in the database and shown in the History View [Sensor Value Events].
A maximum of 1,000 entries can be shown.
Context-Menu
Right Mouse Click - Perform a click with your right mouse button on an entry.
Go To...
Focuses on the corresponding device in the Devices view, the corresponding interface in the Interfaces view, and also shows the event in the History view if recorded data is available.
Clear Events
Removes all logged items from the list.
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected line or lines [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Search
Search - Enter any text in order to search all parameters in the list.
- For example: Desc:Vol shows all lines that include voltage status information by referencing the column Description, for example.
Customization
Right Mouse Click - Perform a click with your right mouse button anywhere on the header of the list.
Timestamp
Shows or hides the Timestamp column.
Category
Shows or hides the Category column.
Network
Shows or hides the Network column.
Shows or hides the Interface IP Address column.
Unique ID
Shows or hides the Unique ID column.
Sub-Device Id
Shows or hides the Sub-Device ID column.
DMX Universe
Shows or hides the DMX Universe column.
Domain
Shows or hides the Domain column.
Label
Shows or hides the Label column.
Description
Shows or hides the Description column.
Resize All Columns To Content
Event Configuration
You can customize and set up if and how you would like to be notified in case of reported events.
Continue with »Event Notifications
MADRIX RADAR 1.4.
 Previous   Next
