▪Introduction
▪Overview
▪Context-Menu
▪Search
▪Options
▪Customization
RDM devices may report back specific occurrences on their own [as supported by the RDM device and as defined by the manufacturer]. As such, you could say that they can have their own log implemented.
The Status Messages view shows all received status messages for the currently selected device.
Timestamp
Shows the local time when the status message has been requested. [YYYY/MM/DD HH:MM:SS]
Type
Shows the type of message [as defined by the RDM standard].
Description
Shows a more in-depth explanation of the message including values [as reported by the device].
Context-Menu
Request Status Messages
(Get:StatusMessages)
Requests up-to-date status messages.
Clear Status Messages
(Set:ClearStatusId)
Sends the RDM request Set:StatusMessages to the device. This clears all status messages on the device. This parameter can only be set. Its status cannot be received and thus it cannot be shown in the overview.
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected row or rows [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Search
▪Search - Enter any text in order to search all parameters in the list.
- For example: Desc:Vol shows all lines that include voltage status information by referencing the column Description, for example.
Options
You can set up specific settings for Status Messages in the Options.
Learn more »Timing
Customization
Timestamp
Shows or hides the Timestamp column.
Type
Shows or hides the Type column.
Description
Shows or hides the Description column.
Resize All Columns To Content
