Parameters
Editing And Changing Values
Context-Menu
Search
Options
Customization
The Parameters view shows all RDM parameters [PIDs including fixed parameter IDs as well as manufacturer-specific IDs] that are supported by the currently selected device [or even currently selected devices].
Represents the parameter numbering as index and is especially useful for referencing parameters in the list.
Parameter
Shows each specific parameter that is supported.
Value
Shows the current value for each parameter.
Associated PIDs
Shows the specific PID or PIDs that are assigned to the parameter.
In general, this overview shows information provided by the RDM device.
In specific cases, the edit icon [that is, a pen] shows that the respective information can be edited by you.
Editing
Left Mouse Double-Click - Perform a double-click with your left mouse button on a value in order to edit it.
- Keyboard shortcut: F2
- Confirm with Enter [or click outside of the currently active cell with the mouse]. Abort any changes with Escape.
You may be presented with different choices for the specific parameter.
In this example, 0x00 or 0x01 is the value that will be sent over RDM.
You may be able to directly enter numbers or text as input.
When having selected several devices in the Devices view and their parameters have different values, the software will display this accordingly.
When changing a value, the change will be made for all selected RDM devices that support this parameter.
Valid Values And Limits
The valid values for each parameter are defined by the RDM device and its set of features [such as DMX Personality], the RDM standard [such as Identify], or a different standard [such as DMX Start Address for DMX512].
Visual Feedback For Edits
The software will show you if any changes you have made are set successfully or not. This status is shown for a couple of seconds after each change.
Green - The RDM device reported back that the changes were successfully set.
Yellow - The request is currently pending.
Red - The fixture could not successfully set the new value or the request timed out.
If you are editing several devices, the list cell can split in the according number of selected devices and show each status individually.
Context-Menu
Right Mouse Click - Perform a click with your right mouse button on a device.
Edit
Allows you to change the entry [if it can be edited]. [Keyboard shortcut: F2]
Request Parameter (Get:ParameterId)
Sends a new request to the device in order to obtain the latest parameter values, which includes all personalities and their corresponding descriptions. [Corresponds to the Get-command of the specific PID if available.]
Copy To Clipboard
Copy Line To Clipboard
Copies the currently selected line or lines [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Save Snapshot As...
Search
Search - Enter any text in order to search all parameters in the list.
- For example: val:MAD shows all lines where MADRIX might be included in a product description for example by referencing the column Value, for example.
Options
You can set up specific settings for Parameters in the Options.
Learn more »Timing
Customization
Right Mouse Click - Perform a click with your right mouse button anywhere on the header of the list.
Shows or hides the Index column.
Parameter
Shows or hides the Parameter column.
Value
Shows or hides the Value column.
Associated PIDs
Shows or hides the Associated PIDs column.
MADRIX RADAR 1.1.
