End-User License Agreement [EULA] |
END-USER LICENSE AGREEMENT FOR INOAGE SOFTWARE MADRIX RADAR Software License Agreement Last Update: 05/2021
This end-user license agreement ('EULA') is a legal agreement between you and the company inoage GmbH ('inoage'). This EULA governs your use of the MADRIX RADAR Software ('software') but not its acquisition, and thereby does not refer to your purchase contract.
IMPORTANT NOTE PLEASE CAREFULLY AND THOROUGHLY READ THIS LICENSE AGREEMENT. MAKE SURE THAT YOU FULLY UNDERSTAND ALL INFORMATION. BY CONTINUING THE INSTALLATION AND/OR BY USING THIS SOFTWARE, YOU CONFIRM THAT YOU HAVE READ THE LICENSE AGREEMENT, ACCEPT ALL OF ITS TERMS AND CONDITIONS WITHOUT RESERVATIONS, AND AGREE THAT YOU THUS BECOME LEGALLY BOUND TO THE TERMS OF THIS LICENSE AGREEMENT.
IF YOU DO NOT ACCEPT THESE TERMS AND CONDITIONS, PLEASE STOP THE INSTALLATION PROCESS. YOU CAN DO SO BY CLICKING 'CANCEL'. IF YOU DO NOT ACCEPT THESE TERMS AND CONDITIONS BUT HAVE ALREADY INSTALLED THE SOFTWARE, PLEASE IMMEDIATELY REMOVE, DELETE, AND DESTROY ALL COPIES OF IT AND ASSOCIATED DOCUMENTS AND DATA.
VALIDITY This license agreement is only valid for the currently used software version as indicated by the software under the menu 'Help > About... > Version'. This license does not automatically extend to any software updates that may be available in the future.
WARRANTY DISCLAIMER AND LIMITATION OF LIABILITY The software or any part thereof is licensed 'as is' and without warranty of any kind.
inoage does not grant guarantee on validity for a particular reason, the marketability, or other properties of the product. There is no way to assert a claim to inoage, neither in the legal way nor in other ways. inoage is not responsible for damages, including all disadvantages that are not just limited to the loss of sales, but that are caused due to the use of the product, due to the loss of serviceability of the product, due to misuse, happenings, circumstances, or actions that inoage does not have influence on, no matter if the damages as well as consequential damages are direct or indirect, incidental or consequential; whether they are special damages or others, nor if the damage is caused by the owner of the warranty or a third person.
Any and all such warranties are disclaimed likewise by contributors, licensors, and third parties of third-party software, SDKs, and drivers that enable specific software features.
You accept that you are using the software at your own and sole risk. This also refers to the level of satisfaction regarding its quality, features, and performance.
USAGE RIGHTS inoage conceded you the limited, non-exclusive right to use this software, and the associated documents and files, in accordance with the terms of this license agreement. The software is 'used' on a computer or similar hardware system when it has been loaded or installed on a storage device of the computer, including but not limited to hard disks, SSDs, non-volatile memory, or similar, or loaded into memory in general. The software usage rights are thus not sold but conceded under license.
Full ownership over the software and all rights that are not expressly granted to you by this license remain with inoage.
DEMO MODE The software can be downloaded for free from the website www.madrix.com and runs in demo mode if you do not connect a valid and activated MADRIX KEY to your computer or use compatible MADRIX hardware interface(s), that is valid MADRIX RDM node(s), to unlock the software's features. Demo mode limits unrestricted usage to the first two RDM devices/sub-devices that are connected. Demo mode can be used for evaluation, demonstration, testing purposes, and productive use.
SOFTWARE LICENSE AND AUTHORIZED USE You can purchase a MADRIX KEY that includes a software license after activation or use valid MADRIX RDM node(s) to unlock the software's features. The MADRIX KEY or MADRIX RDM node(s) can be used flexibly with different computers if needed, but only unlock the full license once, i.e. at one computer at a time. A full license can only be unlocked by using a valid MADRIX KEY with a valid software license or a valid MADRIX RDM node(s).
You are only authorized to use the software extensively and according to its features within the limits of the demo mode as described above or when it is fully unlocked by use of a valid MADRIX KEY with a valid software license or valid MADRIX RDM node(s) especially, but not limited to, for commercial purposes, production work, and lighting control in live productions or fixed installations.
RESTRICTIONS You are not allowed to or allowed to attempt to and agree to not enable others to: (a) add to, alter, decode, decompile, delete from, disassemble, decrypt, edit, modify, recompile, rename, reverse-engineer the whole software or any part thereof (except as expressly permitted by this license regarding open-source components), otherwise attempt to derive or gain access to the source code, reduce the compiled binary assembly to human-readable form, or create derivative works from the software or any part thereof; (b) alter, delete, remove, or obscure any identification of the software, copyright note, or any other notes relating to the property restrictions of the software or any part thereof; (c) bypass, circumvent, overcome, or work around any technical or non-technical means, restrictions, or limitations that are put in place in or together with the software; (d) copy the whole or parts of the software's documentation.
PERMISSIONS (a) You are allowed to install, run, and use the software, as long as you have a valid and activated MADRIX KEY or valid MADRIX RDM node(s) connected to the computer that runs the software. (b) As an exception, you may run the software in demo mode for evaluation, demonstration, testing purposes, and productive use as described above.
TERMINATION This license is effective until terminated. You can terminate it at any time by removing, deleting, and destroying all software files and associated copies. This license will also automatically terminate if you fail to comply with one or more of its clauses. In this case, you must destroy the software and all the associated data, documents, and copies immediately.
COPYRIGHT AND PROPERTY This software and all of its source codes are the exclusive property of inoage, except where otherwise noted, and are protected by the laws in force on the copyright and the intellectual property. MADRIX is a registered trademark of inoage GmbH. All other company and product names may be trademarks of their respective companies.
THIRD PARTIES Third-party copyright information and legal notices are accessible or point to further information under the menu 'Help > About...' or corresponding chapters in the software's user manual.
Certain third-party software, including features provided by the operating system, and/or SDKs and drivers are required for specific software features. Please note that all of these tools may be subject to their own, separate end-user license agreements or similar terms and conditions.
CONTACT You may contact inoage using the following contact details: inoage GmbH Wiener Straße 56 01219 Dresden Germany
Phone: +49 351 862 6869 0 Fax: +49 351 862 6869 68 E-mail: info@madrix.com Web: https://www.madrix.com
ACCESS This EULA will also be made directly available as a text file in the default installation directory of the software.
CONSENT By clicking 'I Agree', you hereby confirm that you have read, consent to the described policies, and accepted the license agreement as provided above.
MADRIX RADAR 1.4. |
