Sensors
  Previous  Next
The Sensors view shows all sensors that are available for the currently selected device or even currently selected devices.
Sensor
Represents the sensor numbering and is especially useful for referencing sensors in the list.  [As defined by the RDM standard, these start with the index 0.]
When having selected multiple devices, you may see that sensors have the same index number. This is implemented intentionally in this way to be able to compare [the same] sensors of different devices.
Status
Shows a helpful graphical representation of the sensor value. This includes:
- Current value [black line],
- Sensor optimal values [green],
- Sensor tolerated values [yellow to orange],
- Sensor minimum and maximum [red].
See also Visual Feedback
Description
Shows the name of the sensor [as reported by the device].
Type
Shows the type of the sensor [as reported by the device].
Total MIN
Shows the absolute minimum value the sensor can read and report [as defined by the sensor/manufacturer].
Normal MIN
Shows the minimum sensor value, which is the lowest acceptable value for the device for normal operation.
Detected MIN
Shows the lowest sensor value that has been reported by the device. Please note that it depends on how the manufacturer has implemented this feature. The manufacturer decides what is being read and what is being reported and when. [The device needs to support the Recorded Value functionality as indicated by Recording Support.]
Present Value
Shows the current value of the sensor.
Detected MAX
Shows the highest sensor value that has been reported by the device. Please note that it depends on how the manufacturer has implemented this feature. The manufacturer decides what is being read and what is being reported and when. [The device needs to support the Recorded Value functionality as indicated by Recording Support.]
Normal MAX
Shows the maximum sensor value, which is the highest acceptable value for the device for normal operation.
Total MAX
Shows the absolute maximum value the sensor can read and report [as defined by the sensor/manufacturer].
Recorded Value
Shows the currently recorded value [as reported by the device].
Recording Support
Shows if the device supports this functionality. Devices can either support recording the current sensor value, detect and store minimum and maximum values, both recording and detecting, or none.
Context-Menu
Right Mouse Click - Perform a click with your right mouse button on an entry.
Request Sensor Values (Get:SensorValue)
Requests up-to-date status information for the selected sensor.
Record Sensor Values (Set:RecordSensors)
Sends the RDM request Set:RecordSensors to the device in order to store the value in the device and request it via Get:SensorValue. This parameter can only be set. Its status cannot be received and thus it cannot be shown in the overview. This will record the current sensor value in the RDM device itself.
Clear Sensor Values (Set:SensorValue)
Sends the RDM request Set:SensorValue to the device. This resets the sensor. This parameter can only be set. Its status cannot be received and thus it cannot be shown in the overview.
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected row or rows [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Visual Feedback
The software will show you if sensors have reported serious or critical values.
If values are out of the optimal range, the entire row will be shown in the same color as would the status indicate:
No visual changes are made to the row if values are within optimal range.
Search
Search - Enter any text in order to search all parameters in the list.
- For example: Sen:Temp shows all lines where a temperature sensor is connected by referencing the column Sensor, for example.
Options
You can set up specific settings for Sensors in the Options.
Learn more »Timing
Customization
Right Mouse Click - Perform a click with your right mouse button anywhere on the header of the list.
Sensor
Shows or hides the Sensor column.
Status
Shows or hides the Status column.
Description
Shows or hides the Description column.
Type
Shows or hides the Type column.
Total MIN
Shows or hides the Total MIN column.
Normal MIN
Shows or hides the Normal MIN column.
Detected MIN
Shows or hides the Detected MIN column.
Present Value
Shows or hides the Present Value column.
Detected MAX
Shows or hides the Detected MAX column.
Normal MAX
Shows or hides the Normal MAX column.
Total MAX
Shows or hides the Total MAX column.
Recorded Value
Shows or hides the Recorded Value column.
Recording Support
Shows or hides the Recording Support column.
Resize All Columns To Content
MADRIX RADAR 1.4.
 Previous   Next
