TRI Fluid
You Are Here:  MADRIX Effects > [TRI] Trigger Effects >
TRI Fluid
TRI Fluid simulates gas or liquids when triggered by you.
The lowest input triggers an explosion to the far left by default. The highest input triggers an explosion to the far right by default. In-between triggers are assigned to in-between positions. Each consecutive explosion uses the next color in the Color Table.
Effect Options
Learn more »Effect Options
Port Settings
Port - Selects the Trigger Port [1 - 64].
- Make sure to select the correct port first.
- This setting should correspond to the settings you have made in the Device Manager. Learn more »Configuration Of TRI
▪Colors - Opens the Color Table or Color Gradient depending on the Color Mode. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta.
▪BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999.
▪Radius - Defines the size of impulses [in %]. The default value is 10. Valid values range from 0 to 100.
▪Vorticity - Defines how much impulses can swirl in the gas [in %]. The default value is 12. Valid values range from 0 to 100.
▪Duration - Defines how long impulses can move through the gas [in %]. The default value is 64. Valid values range from 0 to 100.
▪Density - Defines the thickness of the gas [in %]. The default value is 10. Valid values range from 0 to 100.
▪Velocity - Defines how fast impulses can move through the gas [in %]. The default value is 10. Valid values range from 0 to 100.
▪Fade - Defines how quickly impulses evaporate [in %]. The default value is 5. Valid values range from 0 to 100.
▪Deceleration - Slows down the movement of impulses [in %]. The default value is 0. Valid values range from 0 to 100.
Direction - Allows you to choose the direction of the movement. The default setting is Up. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default setting is Up. Learn more »Using Directions
Color Mode - Allows you to choose the color mode [Color Table or Color Gradient]. The default setting is Color Table.
MADRIX 5.8.
