MADRIX Effects
  Previous  Next
MADRIX 5 offers a large variety of effects. All MADRIX Effects are arranged into 5 distinct categories with various features [SCE, S2L, M2L, TRI, MAS] .
Topics Of This Chapter
»[SCE] Static Color Effects
Static Color Effects produce a multitude of creative lighting patterns and visuals. No extra input or content is necessary. In addition, they provide the tools to load images or video files.
»[S2L]Sound2Light Effects
Sound2Light Effects require an audio input signal. As a result, amazing light effects that are synchronized to the music will be generated!
»[M2L] Music2Light Effects
Music2Light Effects require an audio input signal. M2L Effects go one step further than S2L Effects and analyse music theoretical parameters to create truly unique representations of the music.
»[TRI] Trigger Effects
TRI Effects are based on existing MADRIX Effects. On top, you can trigger them manually using DMX-IN or MIDI. This adds a whole new level of interaction.
»[MAS] MADRIX Script Effect
The powerful Script Editor, which is included in the software, allows you to program your own effects. The script language allows you to easily realize ideas for effects of your own.
»Using BPM Control
Many MADRIX Effects use the BPM Effect Setting to control the speed.
»Using Directions
Many MADRIX Effects allow you to choose a specific movement direction.
»Using Effect Options
Many MADRIX Effects allow you to further define the effect's behavior with additional options.
»Using Shapes [Shape Table]
Certain effects make use of the Shape Table.
»Using Strings [String Table]
Certain text effects make use of the String Table.
»Macros And Scripts
You can control and manipulate running effects using the script language.
MADRIX 5.6.
 Previous   Next
