Using Directions
<< Click To Display Table Of Contents >> You Are Here: MADRIX Effects > Using Directions |
MADRIX 5 Effects have various controls to set up the preferred direction of effects.
▪Directions include all options, including 2D and 3D directions.
▪3D directions can be selected even when you are working in 2D Mode. But they only work correctly in 3D Mode.
▪Especially for 3D a multiple of choices is available. That includes so-called Look-At Types.
Direction - Simply choose a direction by selecting it. The arrows will point towards the direction the effect will take. ▪In the example to the left, the effect will move from up to down. |
Advanced Direction - In addition to the general directions [such as Top, Right, Bottom, Left] specific MADRIX Effects features a large variety of directions. Choose any advanced direction here. |
Front / Back - Allows you to choose the direction as well. This is mainly relevant for 3D. To The Front - The effect will start in the back and move to the front. To The Back - The effect will start in the front and move to the back. |
Look-At Type - Allows you to choose from which side you want to look at the effect. This is mainly relevant for 3D. Front - Positions the effect to see it mainly from the front. Back - Positions the effect to see it mainly from the back. Left - Positions the effect to see it mainly from the left. Right - Positions the effect to see it mainly from the right. Top - Positions the effect to see it mainly from the top. Bottom - Positions the effect to see it mainly from the bottom. |
Cross Mode - Activates Cross Mode. Certain MADRIX 5 Effects can display the effect in two or more directions at the same time. [In addition, the Cross Width defines how much space each direction takes up]. ▪Example 1: SCE Color Scroll with Cross Mode and a Cross Width of 50% will display 2 color scrolls moving in opposite directions. ▪Example 2: SCE Color Scroll with Cross Mode and a Cross Width of 20% will display 5 color scrolls moving in opposite directions. |
None - Stops any movement. |
| MADRIX 5.7. |
