Configuration Of TRI
DMX-IN
MIDI
You need to set up the correct configuration first before you can use MADRIX 5 TRI Effects.
TRI Effects can be triggered in 2 ways:
DMX-IN
[Including DMX512, Art-Net, Streaming ACN]
MIDI
DMX-IN
If you wish to use DMX512, Art-Net, or Streaming ACN as trigger input source, make sure to set them up correctly:
»DMX-IN
»Art-Net Remote
»sACN Input
MIDI
If you wish to use MIDI as trigger input source, make sure to set it up correctly:
»MIDI-IN Configuration
