Layers
You Are Here:  Using The Software >
Layers
Layers Example
MADRIX Effects and Layers are closely related.
Layers can be used to combine visuals and to create completely new effects.
By default, only 1 Layer is created and shown.
You can choose to use only 1 Layer or multiple Layers. Using multiple Layers can alter the displayed visuals immensely.
MADRIX 5 supports an unlimited number of Layers.
[The actual number of Layers available for use depends on your computer performance and Matrix Size.]
This chapter describes ways to work with Layers in particular.
- A general overview about the controls for Layers and MADRIX Effects is provided in a previous chapter. Learn more »Effect Areas [Deck A / Deck B]
Layer Tabs
Every Layer is represented by a Layer Tab.
Layer Order
Left Mouse Click And Hold And Move - Changes the order of Layers via Drag and Drop.
- When changing the order, you change the visual outcome of your effect.
Copy And Paste
Left Mouse Click and 2 Sec. Hold - You can perform a Copy and Paste with the mouse.
Use a left mouse click on a Layer and continue to hold for 2 seconds. A small + appears. Continue to hold and move your mouse to another Layer area. Release the mouse button to paste a copy of the Layer.
Use the keyboard button Ctrl in addition to remove the wait time to immediately perform the drag and drop.
Cut And Paste
Shift + Left Mouse Click And Hold And Move - You can perform a Cut and Paste with the mouse.
Use the keyboard button Shift and use a left-mouse click on a Layer and continue to hold and then move the mouse in order to move the Layer.
Keyboard Shortcuts
Learn more »Keyboard Shortcuts [MADRIX 5]
Layer Name - You can change the Layer's label.
Right Mouse Click > Rename or Double-Click on Layer Tab - Allows you to rename the description label of the Layer tab. Simply enter a new name and click OK
Context Menu
A context menu offers various options when working with Layers.
You can access the Layer context menu in 3 ways:
Right Mouse Click on Layer
Or Right Mouse Click on a Layer Tab
Layer Context Menu
Layer > New - Creates a new Layer.
Layer > Duplicate - Creates an exact copy of the currently selected Layer.
Layer > Copy - Copies the Layer into the clipboard of the computer.
Layer > Cut - Copies the Layer into the clipboard and removes the Layer.
Layer > Paste - Applies all settings of the Layer in the clipboard to the currently selected Layer.
Layer > Insert - Creates a new Layer and applies all settings of the Layer in the clipboard to the currently selected Layer.
Layer > Rename - Allows you to change the label of the Layer.
Layer > Remove - Removes the currently selected Layer entirely.
Various buttons and controls have universal functions. They are available for each MADRIX Effect / Layer:
Effect Parameter Chaser
Effect Parameter Chaser - Controls the Effect Parameter Chaser to add playlist functionality to the Layer. Learn more »Chaser
Layer Macro
Macro Button
Effect Macro Editor - Controls the Effect Macro Editor to add scripting functionality to the Layer. Learn more »Macros And Scripts
Defaults
Submaster
Submaster Button
Submaster
Pulsating Layer in Blind Mode
Submaster - Regulates the intensity of an effect.
Click SUB and the button extends into a fader.
Make sure to click and continue to hold the mouse button at the same time.
Afterwards, simply move the fader with the help of your mouse.
Release the mouse button to set up the specific value [The fader will disappear automatically].
A value of 255 means full intensity.
A value of 0 means no intensity and will render the effect completely black. A value of 0 is shown in red in order to make its severe affect on the visual outcome clear. The button itself and the Layer tab pulsate in red as well.
The tooltip shows the currently set value.
The Submaster allows you to solely adjust the intensity of the running effect or Layer. To adjust the intensity of all running effects you have to use the Master.
Learn more »Main Output / Master / Audio Levels
Map Settings
Modifying the Map Setting allows to freely resize, reposition, and further modify every MADRIX Effect.
Learn more »Mapping / Tiling / Rotation
Mix Modes
Just like an image-editing software, you can use different Mix Modes to mix Layers with each other. This results in diverse color combinations and often completely new effects. These can also be referred to as blend modes.
How Mix Modes Work
Mix Modes are based on basic mathematical calculations.
As such, Mix Modes combine the color values [tonal values] of 2 Layers in different ways. A foreground Layer and a background Layer are used.
All Mix Modes, except for Mask, work pixel by pixel and color channel by color channel.
- Each single pixel of the foreground Layer is combined with the corresponding pixel of the background Layer.
- Each color channel of a single pixel is combined with the equivalent color channel of the corresponding pixel.
Applying A Mix Mode
You can use Mix Modes if you have at least 2 Layers [foreground and background]. Then, you can apply the Mix Mode to the second Layer.
In MADRIX 5, the second Layer is positioned to the right. It is the foreground Layer. In MADRIX 5, the last Layer is on top.
If you apply the Mix Mode to the first Layer, nothing will happen.
You can decrease [or increase] the impact that each Layer has on the visual result by using the Opacity slider.
In the example below, Mix Mode Mask is selected.
How To Use A Mix Mode
By default, Normal is selected.
Right Mouse Click - Resets the filter to its default value [Normal].
SCE Color Effect Example
List Of Mix Modes
Mix Modes
Normal - Is the default setting.
If you do not wish to use a Mix Mode or if you want to deactivate a selected Mix Mode, choose Normal.
Normal is also a Mix Mode and the default way of how Layers are mixed together. Since it is the default Mix Mode, you can only use the Opacity Slider to change the visual outcome. If you set Opacity of Layer 2 to 50%, you will create a result like a cross-fade between the two Layers.
If you change the position of one Layer with the position of the other Layer, the result will not look the same.
Darken - Compares both Layers and only uses the darkest color value for each color channel per pixel [this will be the lower color value].
The result will look the same if you change the position of one Layer with the position of the other Layer.
Multiply - Multiplies the color values of each pixel of Layer 2 with the color values of each pixel of Layer 1.
[Values are converted to always ensure a maximum color value of 255].
Color Burn - Is the inversion of Color Dodge.
Layer 1 will be darkened by Layer 2. The darker Layer 2, the darker the result.
Linear Burn - Is subtractive color mixing.
The color values of both Layers will be added up. But when the result is lower than 255, the values will be set to 0 [black].
Lighten (HTP) - Is the inversion of Darken.
It compares both Layers and only uses the brightest color value for each color channel per pixel [this will be the higher color value].
Is at the same time the Mix Mode HTP, applying the Highest Takes Precedence principle for DMX values.
Screen - Is the inversion of Multiply.
Layer 2 and Layer 1 will be negatively multiplied and often brighten each other.
Color Dodge - The brighter Layer 2, the brighter will be Layer 1.
A completely black Layer 2 will not change Layer 1.
A completely white Layer 2 will brighten every color channel, except for black color values.
Linear Dodge - Will simply add up the color values of both Layers.
Overlay - Is a combination of Multiply and Screen.
The result depends the intensity of Layer 1. If Layer 1 is darker than 50% Gray, the color values of both Layers will be multiplied. If Layer 1 is brighter than 50% Gray, the color values will be negatively multiplied and the amount will be doubled. A Layer 2 with 50% Gray will have no affect on Layer 1.
Soft Light - Layer 2 will modulate the color values of Layer 1 and create soft mixtures in areas of highlights and shadows.
[Overlay is quite similar, but creates sharp contrasts instead.]
Hard Light - Creates the result of Overlay, when changing the position of Layer 2 with the position of Layer 1.
It compares the intensity of both Layers.
If Layer 2 is brighter than 50% Gray, Layer 1 will be brightened.
If Layer 2 is darker than 50% Gray, Layer 1 will be darkened.
Vivid Light - Will mainly increase the contrast of highlights and shadows.
The result is like a combination of Color Burn for shadows and Color Dodge for highlights.
Linear Light - Increases the contrast.
It is similar to Linear Burn, but color values of Layer 2 have greater affect.
Pin Light - Is like a combination of Darken and Lighten.
It compares the color values of both Layers and creates one of three results. Average color values will often remain unaffected.
The result can be twice the brightness of Layer 2 darkened by a full 255 if Layer 1 is darker than that.
The result can also only be Layer 1 if Layer 1 is brighter than the first result and darker than the third result.
Or the result can be twice the brightness of Layer 2 if Layer 1 is brighter than that.
Hard Mix - Only uses the six primary colors red, green, blue, yellow, cyan, magenta, or black, or white.
Color channels will be mixed and either be set to 0 or 255. [255 will be set for every color channel result from 1 to 254. 0 will be set, when the color channel result is 0.]
Difference - Will calculate the difference between color values for each pixel.
[If the result is negative, it will be multiplied by -1 to always have positive color values.]
Differences in color values will be easily visible for each pixel. If both pixels are identical, the difference will be 0 and thus black could be the maximum result for a pixel.
Exclusion - Bright color areas will invert the color values of the corresponding area of the other Layer.
White areas will completely invert the color.
Very dark areas [black] will change nothing on the other Layer.
Average gray values will heavily change the contrast, up to a complete gray.
Subtract -
Divide -
Mask - Uses the alpha channel of Layers.
It will merge the Layers together. The result will only be visible on areas where the two Layers overlap. The rest will be set to black.
Negative Mask -
Link
Link Button
Link - Combines 2 Layers with each other.
If you activate Link mode, the currently selected Layer will be linked to the Layer underneath. It means that it will be linked to the Layer left to it.
Example 1
1] Select a Storage Place and create 2 Layers . Choose SCE Ticker / Scrolling Text for Layer 1. Choose SCE Plasma for Layer 2.
Link Mode Example 1
adsda
2] As a first result, you will see the following image in the Previews. Because of the standard settings, the Layer order, and the 2 Layers, only SCE Plasma is visible.
Link Mode Example 2
Without Link Mode
3] Activate Link Mode. The button glows green.
Link Mode Example 3
4] As a result, both Layers will be merged and the preview looks completely different. The text will be filled with the Plasma effect and in this way, both Layers are used to create a new effect.
Link Mode Example 4
With Link Mode
Example 2
You could describe Link Mode differently.
As previously described, effects may be build out of several Layers. Each Layer can contain a different MADRIX Effect.
All Layers of that effect will be used to render the visual outcome. When rendering the visuals, Mix Modes, Opacity, position of Layers, etc. will all be included in the render process.
Because of this, Link Mode can also be very useful when using more than two Layers.
Use Link Mode and MADRIX 5 will handle two linked Layers like one Layer in the render process.
1] Select a Storage Place and create 3 Layers. Choose SCE Metaballs for Layer 1. Choose SCE Ticker / Scrolling Text for Layer 2. Choose SCE Plasma for Layer 3 and activate Link Mode for Layer 3.
Link Mode Example 6
2] As a result, you can see that the Plasma effect of Layer 3 is only visible on the text of Layer 2. The Metaballs effect [Layer 1] has not been affected at all.
Link Mode Example 7
3] If we now add a fourth Layer [SCE Gradient at Layer position 2] and activate Link Mode for this Layer, we will see that the text looks still the same. But the Metaballs effect [Layer 1] now has the colors of the Color Gradient.
Link Mode Example 8
Link Mode Example 9
Filters [FX]
Filters - Special filters can be applied to Layers in order to quickly change your visuals. Learn more »Filters [FX]
Stepped Rendering
Stepped Rendering - Is only available for specific MADRIX Effects. It only applies to any movement of the input, i.e. when a Direction other than Stop is activated. Instead of creating a smooth transition for the movement from one voxel to the next voxel [sub-pixel rendering], MADRIX 5 will move the input from voxel to voxel and from step to step without this transition. This might create a rougher overall movement, but it can produce a visually better outcome on the LEDs in certain cases [such as slow movement of large text].
Opacity
Layer Opacity
Layer Opacity - Makes the Layer transparent. This is mainly useful when using at least 2 Layers or more.
- If you are using only 1 Layer, the submaster controls the Layer brightness.
- The default value is 255 [100%].
- Perform a right-click to reset to 255 [100%].
- A value of 0 means no opacity and will render the effect completely black. A value of 0 is shown in red in order to make its severe affect on the visual outcome clear. The button itself and the Layer tab pulsate in red as well.
Blind And Solo
Blind Mode and Solo Mode are 2 modes to quickly hide or show Layers. You can quickly include or exclude them from the visual end result of your effect.
Blind Button
Blind - Hides the currently selected Layer.
- The Layer will not be visible anymore in the Previews and Output, but you will still be able to adjust its settings. In this way, you may have a look at your created effect excluding certain Layers.
- Blind Mode will stay activated even if you switch to other Layers or Storage Places.
- The Layer tab will pulsate in red if Blind Mode is active.
- Blind Mode also affects Link Mode. A Layer with an activated Link Mode will also be set to Blind Mode if Blind Mode is activated for the Layer it is linked to.
Solo button
Pulsating Layer in Solo Mode
Solo - Hides every Layer except the currently selected Layer. Hence, this Layer is the only one that will be displayed.
- Solo Mode will stay activated even if you switch to other Layers or Storage Places.
- The Layer tab will pulsate in green if Solo Mode is active.
- Solo Mode overrides Blind Mode.
Layer View
You can switch between 2 views.
By default, the regular Effect Area is shown.
Layer View
Layer View - Activates the second view available for Layers.
- The user interfaces changes as shown below [4 Layers are currently active in this example].
When switching between Storage Places, the last used view will be remembered by the software.
Solo And Blind
Solo - Activates Solo Mode for the corresponding Layer.
Blind - Activates Blind Mode for the corresponding Layer.
Faders
Each fader regulates the Opacity of a single Layer.
- You can set the fader to a specific position.
- You can enter a value in the input field.
- You can flash the fader.
- A value of 0 is shown in red in order to make its severe affect on the visual outcome clear. The Layer tab itself pulsates in red as well.
Mouse Control And Keyboard Shortcuts
Single Selection
- A single fader regulates the Opacity of the corresponding Layer.
- Left Arrow / Right Arrow - Quickly switch between faders by using the left or right arrow key.
Multiselection
- Use Ctrl + Left Mouse Click to select multiple faders at the same time. A green outline will show that a Layer is selected. When multiple faders are selected, you can control them at the same time.
- Use Shift + Left Mouse Click to select multiple faders at the same time. A green outline will show that a Layer is selected. When multiple faders are selected, you can control them at the same time.
- Ctrl+A - Selects all faders of all Layers.
- Ctrl+D - Deselects the current fader selection.
Flash
- Use the button showing the Layer's Name or the keyboard shortcut Spacebar
- It instantly sets the intensity to 255 as long as you hold the button/key down.
- To use this feature, the fader needs to be set to a lower value than 255 first.
Restoring The Default Value
- Left Mouse Double-Click - Perform a double-click with your left mouse button directly on a single or multiple faders to restore the Default Value
- Right Mouse Click - Perform a click with your right mouse button directly on a single or multiple faders to restore the Default Value
MADRIX 5.7.
