SCE Rotating Shapes
SCE Rotating Shapes displays various shapes that circle around a centric point.
Shapes - Opens the Shape Table to specify the shapes. The default color is Circle Filled.
Learn more »Using Shapes [Shape Table]
Path Count - Defines the number of concentric paths on which shapes circle around the center. The default value is 3. Valid values range from 1 to 20.
Path Bounds - Defines the inner and outer limits of where paths can run along on the virtual LED matrix. The default values are 10 and 90. Valid values range from 0 to 10000.
Offset - Defines a location deviation of shapes across different paths. The default value is 0. Valid values range from -10000 to 10000.
Shape Count - Defines the number of shapes [multiplied by the Patch Count]. The default value is 1. Valid values range from 1 to 50.
Size - Defines the minimum and maximum size of shapes. Outer shapes are large than inner shapes. The default value are 10 and 20. Valid values range from 0 to 1000.
Rotation - Defines the number of path on which shapes circle around the center. The default value is 0. Valid values range from -3600 to 3600.
Center - Defines the position of the center in X, Y, and Z [in %]. The default values are 50, 50, 50. Valid values range from -1000 to 1000.
Path Alignment - Lets shapes rotate along the path instead of the rotation against the horizon.
Motion - Activates movement across the different paths defined by the Path Count. The default setting is 0. Valid values range from -100 to 100.
Linear - A linear distribution is used to increase the size regularly.
Quadratic - The majority of objects will be smaller than the rest.
SQRT - Using a square root function the majority of objects will be larger.
Cubic - Uses a cubic distribution with mixed sizes.
Shape On Bounds - Locats shapes on each Patch Bound instead of placing them towards the Paths Bounds.
Offset Animation - Animates the shapes and rotates them additionally with the offset against each path.
Path Cross Width - Lets shapes move against each other on the different paths. The default setting is 0. Valid values range from 0 to 20.
Uniform - Each path has the same distribution.
Linear - A linear distribution is used to increase the parameter regularly starting from the inside.
Quadratic - The parameter is more prominent on the outer paths.
SQRT - Using a square root function the parameter is more prominent on the outer paths.
Cubic - Uses a cubic distribution with a mixed distribution.
Inverted Linear - A linear distribution is used to decrease the parameter regularly starting from the inside.
Triangle - The majority of objects will be on the middle paths.
Inverted Quadratic - The parameter is more prominent on the inner paths.
Inverted SQRT - Using a square root function the majority of objects will be on the inner paths.
Inverted Cubic - Uses a cubic distribution with a mixed distribution.
Rotation Animation - Animates the shapes and rotates them individually and permanently.
Rotation Cross Width - Lets shapes rotate against each other on the different paths. The default setting is 0. Valid values range from 0 to 20.
Speed - Is only available for specific shapes [Implode, Explode, Pulse]. Defines how fast the shapes implode, explode, or pulse. The default setting is 1. Valid values range from 0 to 10.
Delay - Is only available for specific shapes [Implode, Explode, Pulse]. Adds a delay to the shapes and lets them implode, explode, or pulse across the different paths. The default setting is 0. Valid values range from -100 to 100.
Delay 2 - Is only available for specific shapes [Implode, Explode, Pulse]. Adds a delay to the shapes and lets them implode, explode, or pulse along each path. The default setting is 0. Valid values range from -100 to 100.
Display Mode - Defines how the effect is shown. The default setting is Fit.
Clip - The maximum size of the effect is determined by the largest side of the virtual LED matrix.
Fit - The maximum size of the effect is determined by the smallest side of the virtual LED matrix.
Stretch - The effect is stretched to be fully shown on the virtual LED matrix.
