▪Introduction
▪Overview
▪Layer Settings
▪Effect Settings
▪Configuration
▪Slices
SCE Screen Capture allows you to use any area of your Windows Desktop / Monitor / Screen and capture its content in order to directly bring it into MADRIX 5. In this way, you can integrate any other software and their output into MADRIX 5 [such as visualizers, presentations, and more]. Basically anything that you can show on your monitor can also be brought into MADRIX 5.
▪Filter - Defines a filter color. The default color is White.
▪BPM - Defines the speed [when using a direction/movement]. The default value is 1500. Valid values range from 0 to 9999.
▪Position - Defines the position of the object in X, Y, and Z [in %]. The default values are 0, 0, 0. Valid values range from -1000 to 1000.
▪Extrusion - Adds depth to the input; i.e. duplicates the input image [in % of the Matrix Size]. This is mainly relevant for 3D. The default value is 100. Valid values range from 0.01 to 100.
▪Dynam. Range - Defines the dynamic range of the output. Valid values range from 0 to 255.
- The default value range is 0 to 255, which means that all available color values of the input will be displayed.
- Adjusting the left value cuts of lower color values and defines a new black level; therefore eliminating unwanted [gray] noise and achieving a uniform black.
[Setting the left value to 255 will render the input completely black.]
- Lowering the right value highlights the colors; therefore achieving purer color values.
[Setting the right value to 0 will render black/gray values completely white.]
▪Delay - Adds an output delay to the captured input [in milliseconds]. The default value is 0. Valid values range from 0 to 1000.
Configuration - Allows you to configure the effect. It is highly recommended to adjust the settings. Learn more Configuration
Slices - Is a way to bring 2D content to 3D LED matrices by slicing the content into different parts and applying each slice to X-levels, Y-levels, or Z-levels as required. Learn more Slices
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default setting is None.
Rotation - Allows you to rotate the input [0°, 90°, 180°, 270°]. The default setting is 0°.
Tile - Allows you to tile and duplicate the input and thereby generating patterns.
Seamless - Activates or deactivates a continuous stream of the input image. MADRIX 5 will automatically display the input image again to create a continuous display.
Stretching / Aspect Ratio - Allows you to choose the aspect ratio of the input. The default setting is Matrix.
None - Disables stretching.
Configuration
▪ In order to use this MADRIX 5 Effect, click Configuration first.
▪A new window opens.
▪Configure the Screen Capture Configuration as required and as explained below.
Capture Frame Rate
▪FPS - Defines the frame rate with which MADRIX 5 captures the content.
D - Restores the default settings. The default value is 50.0 FPS.
Capture Area
These settings define the screen area that is used for the screen capturing.
Preset
▪Allows you to choose a preset for your capture area:
Custom Size - Defines a custom area as the capture area.
- Is automatically selected if you use a Selection Tool or define a Custom Area.
Monitor - Defines a complete output of one monitor as the capture area. The available selection choices depend on the configuration of monitors in Windows [e.g., if one or more monitors are installed].
Virtual Screen - Defines the complete screen output of Windows as the capture area. This often includes all monitors, for example.
Selection Tool
▪Allows you to define a Custom Area using one of two tools:
Marquee - Allows you to define a capture area via your mouse and keyboard.
- Click Marquee and an overlay will be shown.
- You can freely move the overlay around in order to position it correctly.
- To do so, use the mouse [left mouse click and hold and drag the overlay window].
- Or use the arrow keys on your keyboard [Left, Right, Up, Down].
- You can freely change the size of this overlay in order to set up the correct size.
- To do so, use the mouse and drag the edges of the overlay.
- Or use the following keyboard shortcuts:
- Shift + Arrow Up / Arrow Down - Reduces the Height.
- Ctrl + Arrow Up / Arrow Down - Increases the Height.
- Shift + Arrow Left / Arrow Right - Reduces the Width.
- Ctrl + Arrow Left / Arrow Right - Increases the Width.
- The upper left coordinates of the overlay [Left, Top] are always displayed in the upper left corner.
- The lower right coordinates of the overlay [Right, Bottom] are always displayed in the lower right corner.
- The Width and the Height of the overlay are always displayed in the center.
- Escape / Enter / Left Mouse Double-Click - Confirms your selection.
Window - Allows you to quickly choose a specific window to use as capture area.
- Click Window and an overlay will be shown that covers complete windows.
- You can freely choose which window should be used as screen capture area.
- Move the mouse to select the window via the overlay.
- Use Ctrl + left mouse click in order to select specific parts of a window [e.g., to select only a specific area of an application].
Custom Area
▪ Define an individual screen capture area by using the four input fields.
Left and Top - Define the start coordinates in a coordinate system that starts with 0,0 in the top left corner.
Width - Defines the total horizontal size of the screen capture area in X.
Height - Defines the total vertical size of the screen capture area in Y.
Slices
SL - Calls up Slice Settings
▪Slice Settings - Is a way to bring 2D content to 3D LED matrices by slicing the content into different parts and applying each slice to X-levels, Y-levels, or Z-levels as required. [You will get the most benefit out of this feature when using content that are made up of different parts and are especially created for this area of application.]
Example: Your virtual LED matrix is 10 x 8 x 4. Now, you have prepared a video feed and want to display it not only on the first Z-level or use Extrude, but on all 4 Z-levels. Then, you would let MADRIX 5 create 4 slices.
▪Slice Type - Defines the 3D orientation of how slices are applied to your LED matrix.
▪Slice Order - Defines how your source content is processed.
- Left To Right - MADRIX 5 slices the content starting left.
- Right To Left - MADRIX 5 slices the content starting right.
- Top To Bottom - MADRIX 5 slices the content starting top.
- Bottom To Top - MADRIX 5 slices the content starting bottom.
▪Slice Count - Defines in how many slices the content is divided. A value of 1 means that no slices are created and that the video feed is used as one. [A value of 4, for example, will create 4 slices that each make up 25% of the source content.]
▪The settings with the highest performance are Z-Slices and Top To Bottom
▪Confirm with OK, restore the default settings via Defaults, or abort the process using Cancel
▪Learn more »SCE Image
