SCE Pulse / Stroboscope
SCE Pulse / Stroboscope produces a stroboscope or pulsating effect.
BPM - Defines the speed. The default value is 1080. Valid values range from 0 to 9999.
Ratio - Defines the ratio and relation between Fade In and Fade Out [in %]. The default value is 50. Valid values range from 0 to 100.
- A Ratio of 50 means that Fade In and Fade Out have the same duration.
- A Ratio of 0 means that there is a Fade In, but no Fade Out.
- A Ratio of 100 means that there is no Fade In, but a Fade Out.
Fade - Activates or deactivates fading between colors.
- When activated, the effect pulses.
- When deactivated, the effect strobes.
