SCE Fill Drops
SCE Fill Drops
SCE Fill Drops creates randomly falling objects.
Effect Options
Learn more »Effect Options
Fill Time - Defines the time how long it takes to fill the complete LED matrix with shapes [in s]. The default value is 5. Valid values range from 0.01 to 3600.
Duration - Defines the time the complete matrix is shown in solid color until the next round of objects begins to fill the matrix [in s]. The default value is 1. Valid values range from 0 to 3600.
Size - Defines the size of objects [in % of the Matrix Size][Width, Height, Depth]. The default values are 10, 10, 10. Valid values range from 0.01 to 1000.
Pitch 1 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 0. Valid values range from 10 to 100.
Pitch 2 - Defines the second distance between objects depending on the direction [in % of the Matrix Size]. The default value is 0. Valid values range from 10 to 100.
Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 0.01. Valid values range from 0.01 to 100.
Blending Mode - Is only available when colors are defined with an alpha value in the Color Table. Defines how shapes and colors are blended [Alpha Blending, Substitution].
Alpha Blending uses the alpha channel to blend overlapping shapes with each other [i.e. if the Pitch is smaller than the Size].
Substitution replaces colors, and when using alpha this is especially visible when using two or more Layers.]
Flush - Clears the matrix with the last used color before starting a new cycle. Is activated by default. Is visible for shapes other than Rectangle.
Position Origin Type - Defines the point of origin of Shapes [and hence their relative position].
Outer Glow / Inner Glow - Is only available for specific Shapes. Defines the outer shimmer or inner gleam of objects. The default settings are 0.00. Valid values range from 0.01 to 100.
Direction - Allows you to choose the direction of the movement. The default setting is Down. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default setting is Down. Learn more »Using Directions
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default setting is Rectangle Filled.
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [, 90°, 180°, 270°, Random]. The default setting is 0°.
MADRIX 5.7.
