SCE Fill Random |
SCE Fill Random continuously adds new objects until the whole LED matrix is filled.
▪This MADRIX Effects supports Effect Options for advanced workflows. Learn more »Effect Options
This MADRIX Effect uses the following, individual controls: ▪Colors - Opens the Color Table to specify the colors. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta. ▪Fill Time - Defines the time how long it takes to fill the complete LED matrix with shapes [in s]. The default value is 5. Valid values range from 0.01 to 3600. ▪Duration - Defines the time the complete matrix is shown in solid color until the next round of objects begins to fill the matrix [in s]. The default value is 1. Valid values range from 0 to 3600. ▪Size - Defines the size of objects [Width, Height, Depth]. The default values are 10, 10, 10. Valid values range from 0.01 to 1000. ▪Pitch - Defines the distance between objects for all 3 axes. The default values are 10, 10, 10. Valid values range from 0 to 100. ▪Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 0.01. Valid values range from 0.01 to 100.
MADRIX 5.6. |
