SCE Explosions
SCE Explosions displays all kinds of explosions as well as fireworks.
Colors - Opens the Color Table. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta.
BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999.
Explosion Size - Defines the magnitude of each explosion. The default value is 400. Valid values range from 1 to 9999.
Shape Size - Defines the size of each object within an explosion. The default value is 8. Valid values range from 1 to 100.
Explosions - Defines how many explosions are displayed at the same time. The default value is 1. Valid values range from 1 to 100.
Shapes - Defines the number of single objects a single explosion includes. The default value is 75. Valid values range from 1 to 1000.
Fade Out - Defines how fast MADRIX 5 displays objects. The default value is 20. Valid values range from 0 to 1000.
Gravity - Defines how strong objects are pulled to the bottom depending on the direction [in %]. The default value is 0.25. Valid values range from 0 to 100.
Colors - Opens a second Color Table to define the second colors of each explosion. The default color is White.
Outer Glow / Inner Glow - Is only available for specific Shapes. Defines the outer shimmer or inner gleam of objects. The default settings are 0.00. Valid values range from 0.01 to 100.
Explosion Shape - Allows you to choose a specific shape for explosions [Sphere, Sphere Glow, Spiral, Radial, Diamond, Star, Random]. The default setting is Random.
Direction - Allows you to choose the direction of the movement. The default setting is Up. Learn more »Using Directions
Direction - Allows you to choose the direction of the movement [To The Front or To The Back]. This is mainly relevant for 3D. The default setting is Up. Learn more »Using Directions
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default setting is Square Filled.
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [, 90°, 180°, 270°, Random].
Rendering Mode - Defines how objects are rendered. Each mode may enable additional settings [such as additional Shapes]. Choose from 2 different modes. The default setting is Simple.
Mode - Allows you to choose the mode [Explosions or Fireworks]. The default setting is Explosions.
