S2L Waveform |
S2L Waveform displays the audio input graphically. It is a timeline representation.
▪This MADRIX Effects supports Effect Options for advanced workflows. Learn more »Effect Options
This MADRIX 5 Effect uses the following, individual controls: ▪Color - Defines the color using a Color Gradient control. The default color is Red, Yellow, Green, Cyan, Blue, Magenta. ▪BPM - Defines the speed. The default speed is 60. You can either use BPM or Time Slot. Valid values range from 0 to 9999. ▪Time Slot - Defines the time interval [in s]. The default value is 1. You can either use BPM or Time Slot. Valid values range from 0.01 to 9999.
MADRIX 5.6. |
