S2L Tubes
You Are Here:  MADRIX Effects > [S2L] Sound2Light Effects >
S2L Tubes
S2L Tubes display the frequencies of the audio signal in form of various tubes.
Effect Options
Learn more »Effect Options
▪Color - Defines the color. The default color is White.
▪Fade - Defines how fast MADRIX 5 displays the effect. The default value is 60. Valid values range from 1 to 3000.
▪Size 1 - Defines the first size of tubes depending on the direction [in % of the Matrix Size]. The default value is 10. Valid values range from 0.01 to 100.
▪Pitch 1 - Defines the first distance between tubes depending on the direction [in % of the Matrix Size]. The default value is 10. Valid values range from 0.01 to 100.
▪Size 2 - Defines the second size of tubes depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100.
▪Pitch 2 - Defines the second distance between objects depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100.
▪Alpha Mix - Defines the upper limit of how much alpha is added to each object [in %]. Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100.
▪Sensitivity - Defines how quickly and accurately MADRIX 5 reacts to the audio input [in %]. The default value is 50. Valid values range from 0 to 100.
Shift - Shifts the position of equalizer bands [in %]. By default, lower frequencies are shown to the left and high frequencies are shown to the left. The default setting is 0. Valid values range from 0 to 100.
Amplification - Amplifies the audio input and as a result increases the visual intensity [in %]. The default setting is 0. Valid values range from 0 to 100.
Vertical Mode - Activates or deactivates the use of vertical objects. All 3 modes can be used at the same time.
Horizontal Mode - Activates or deactivates the use of horizontal objects. All 3 modes can be used at the same time.
Depth Mode - Activates or deactivates the use of objects in the depth. All 3 modes can be used at the same time.
Mode - Allows you to choose the mode in which way objects are generated [EQ, Level Mono, or Level Stereo]. The default setting is EQ.
MADRIX 5.8.
