S2L Wavegraph
You Are Here:  MADRIX Effects > [S2L] Sound2Light Effects >
S2L Wavegraph
S2L Waveform displays the audio input as a graph.
BPM - Defines the speed. The default speed is 6000. You can either use BPM or Time Slot. Valid values range from 0 to 9999.
Time Slot - Defines the time interval [in s]. The default value is 0.01. You can either use BPM or Time Slot. Valid values range from 0.01 to 9999.
Direction/Mode - Allows you to choose the direction, including Look-At Type. This includes all directions for 2D and 3D mode. This heavily influences the visual outcome of the effect. The default setting is Left. Learn more »Using Directions
Channel - Allows you to choose the displayed audio channels [Stereo, Mono, Left, Right]. The default setting is Mono.
MADRIX 5.8.
