Devices (Network)
To access options of MADRIX, please press "Ctrl+Alt+O" or go to the menu "Preferences" -> "Options". Now go to the tab "Devices (Network)".
Devices (Network)
Configuration
If you enable the drivers in this menu, MADRIX automatically starts searching for known and supported network devices at startup.
You can enable six particular network drivers here:
e:cue - e:net
Robe StageQube324 / Insta Light2022
Philips Color Kinetics - KiNet
ESTA - Streaming ACN
inoage - MADRIX
Capture - CITP Networking Protocol
Please always make sure that you have selected the correct network.
Tips
You can speed up the loading/starting time of MADRIX. Please only activate drivers for devices which you are going to use.
More Information
Please read the corresponding chapter to configure MADRIX further:
e:net from e:cue
ROBE StageQube 324
Insta Light 2022 - LED-Panel RGB 324
MADRIX PLEXUS
MADRIX LUNA
All options of Devices (Network) will be saved locally on your computer. The settings here will not be saved in your MADRIX Setup file.
