Philips Color Kinetics (KiNet) |
MADRIX natively supports Philips Color Kinetics. The necessary protocol is implemented in the software, which makes it easy to use Color Kinetics fixtures with MADRIX.
Network Settings The factory settings for the power supplies start with a default IP address range of 10.0.0.x. Please use these IP addresses! You will have to set these settings in Windows. Please open the properties of your network connection and adjust the values. It should look like this:
To send data using all network cards of your computer, simply enter 255.255.255.255 (IP address) and 0.0.0.0 (subnet mask). Please restart MADRIX if you have changed any network settings in Windows.
Configuration For the administration of the Philips Color Kinetics - KiNet network driver, please enable the network driver first. Go to the menu "Preferences" -> "Options" or the press the keys "Ctrl-Alt-O". Select the tab "Devices (Network)".
Here you can enable and disable the Color Kinetics KiNet network driver. Simply activate the check box "Enable Kinet". Please also select the network card, you wish to use. The network cards is shown in MADRIX with the help of its IP address, subnet mask and connection speed. Please always make sure that you have selected the correct network. Otherwise, the network device might still be found. But no data can be sent.
Use the edit field "Time To Detect Devices (s)" to define how long MADRIX searches the network for KiNet network devices/power supplies (type in a value in seconds). We recommend to utilize at least a value of 10 to allow for a sufficient search.
In the next step, open the "Device Manager" (press "F4" or open the menu "Preferences" -> "Device Manager").
Go to the tab "DMX Devices" and decide which of the listed devices are used as output devices. If you click on "Enable" and "Output", the data will be sent to this device. Check also if every device is assigned a different universe (right hand side of the window). Please check if the DMX universes are assigned correctly!
There is a difference between KiNet V1 and V2. KiNet V2 makes sure that the panels will receive the data at the same time. This is particularly useful for large installations. Please see the Color Kinetics documentation to see which protocol is supported by your power supply.
In the exemplary picture above, you can see 2x KiNet V1 and 1x KiNet V2 power supplies assigned to universe 1 to 3 with the IP addresses 10.0.159.189, 10.0.68.54, and 10.0.65.4.
Rescan For Devices
Highlight Mode
Select one or more interfaces and press the button. The corresponding fixtures at the selected interface(s) will flash for a better identification. This makes it easier to see them on stage. It considerably speeds up the procedure of programming the selected DMX512/Art-Net interfaces.
DMX Watcher
Resizing The Window If wish to resize the window of the Device Manager to see more devices in the list, simply move your mouse pointer to the bottom of this window. Then, select the border and hold the left mouse button, while moving your mouse downwards.
Further Configuration
Please remember to configure your light matrix in the Matrix Generator or Patch. Please make sure to save your MADRIX Setup after the configuration process.
Important Notes Please keep in mind that network devices, if activated, cause network traffic! When using a network-based output protocol and when the start option "Run MADRIX, When Windows Starts" is used, it is highly recommended to also activate the start option "Set Timeout To Start Software" with a value of "30".
Checklist To Solve Problems If you are encountering problems, please work through the following checklist:
Additional Information Addressing And Configuration Regarding the configuration and addressing of Philips Color Kinetics lighting fixtures and power supplies, the company offers extensive information on the following website: http://www.colorkinetics.com/support/addressing/ In addition, there is a software tool called QuickPlay Pro for configuration and multiple addressing. Here is an excerpt from the website: "With QuickPlay Pro, you can:
For example, the tool can be used to change the IP addresses of Color Kinetics lighting fixtures. Please note: Working with such a tool is only recommended for advanced users because settings can easily be adjusted wrong! You can download the tool on the website mentioned above or at http://www.colorkinetics.com/support/downloads/ The download archive for older products can be found at http://www.colorkinetics.com/support/downloads/archive/
Information About PDS-60ca Power Supplies The PDS-60ca is a well-known and often used power/data supply from Philips Color Kinetics. Three different versions are offered:
You can identify your version of the device using the following item numbers written on the case of the PDS-60ca:
The PDS-60ca DMX supports DMX512 via an extra interface (controlled by MADRIX) or Color Kinetics DMX controllers. Information Update The official website now only lists two PDS-60ca. The second power supply now automatically switches between DMX and Ethernet mode.
