Devices (USB/PCI)
To access options of MADRIX, please press "Ctrl+Alt+O" or go to the menu "Preferences" -> "Options". Now got to the tab "Devices (USB/PCI)".
Devices (USB/PCI)
Use Device Driver
MADRIX can be configured to search automatically for all known and supported devices using USB, PCI, PCMCIA, DMX512, etc. at the software start-up. Activate a check-box in order to enable the use of a certain interface driver.
Please note: If you only activate drivers for devices which you are effectively going to use,
you can speed up the loading/starting time of MADRIX.
you can avoid problems with other interfaces.
you can avoid problems with other software running on your computer which also controls such DMX interfaces.
More Information
This user guide provides further information: Supported DMX512 & Art-Net Interfaces.
Further Configuration
For more information about the configuration of your DMX devices, please see the chapter DMX512 (DMX-OUT).
All options of the tab Devices (USB/PCI) will be saved locally on your computer. The settings here will not be saved in your MADRIX Setup file.
