ROBE StageQube 324 (ROBE Protocol)
Robe StageQube 325
To use the ROBE StageQube 324™, a separate DHCP server is required. This can be a software or hardware DHCP server, which handles the IP addresses of the ROBE StageQube 324™ and the MADRIX computer. A good idea and option is to activate that the DHCP server binds MAC addresses to IP addresses.
ROBE Configuration Illustration
ROBE Set-up Illustration
Configuration
We recommend to use an IP address range of 10.0.0.x for MADRIX and ROBE StageQube 324™. The subnet mask should be 255.0.0.0
For the use of ROBE StageQube 324™, we suggest to only use 1000Mbit network components. That means 1000Mbit network cards in your computer, 1000Mbit switches and a DHCP server with support of 10/100/1000Mbit if your setup looks like the configuration shown above.
Please restart MADRIX if you have changed any network settings in Windows.
Please enable the network driver in MADRIX. Go to the menu "Preferences" -> "Options" or the press the keys "Ctrl-Alt-O". Select the tab "Devices (Network)".
Devices (Network)
Here you can enable and disable the ROBE/Insta network driver. Use the edit field "Time To Detect Fixtures (s)" to define how long MADRIX searches the network for ROBE StageQube 324™ network devices (type in a value in seconds).
We recommend to utilize at least a value of 10 to allow for a sufficient search.
Higher values are recommended for larger installations.
Please always make sure that you have selected the correct network. Otherwise, the network device might still be found. But no data can be sent.
In the next step, open the "Device Manager" (press "F4" or open the menu "Preferences" -> "Device Manager").
Preferences - Device Manager
Go to the tab "DMX Devices" and decide which of the listed devices are used as output devices. If you click on "Enable" and "Output", the data will be sent to this device. Check also if every device is assigned a different universe (right hand side of the window).
Please check if the DMX universes are assigned correctly!
DMX Devices
In the example above you can see 4x ROBE StageQube 324™ starting at universe 1 to 4 with IP addresses from 10.0.0.20 to 10.0.0.23.
Device Configuration
The option "Configure Device" (use the button or double-click the device) allows you to set up various parameters of the selected Robe panel. Those include: Brightness, Contrast, Luminesce Time, Frequency, and the values for Red, Green, and Blue for the left half and the right half of each ROBE StageQube 324™.
Multiple Selection
Please note: You can also select multiple ROBE StageQube 324™ and change all the settings in one step.
Enabling the "Live Preview" switches to receive parameters live from the device. By clicking at the button "Set Default", you will reset it to factory default values.
Enable DeviceSetting up the "Frame Time" is particularly useful if you have connected different devices each rendering different output frame rates and you want to sync them to a specific frame rate. Or it might be that the LED fixtures you attached have problems with fast frame rate. You are able to slow down the frame time by typing in larger values in ms in that case.
Rescan For Devices
Rescon for Devices ButtonIf you click the "Rescan For Devices" button, MADRIX disconnects all DMX512, Art-Net, and other network devices and starts a new search for devices.
Highlight Mode
Highlight Device ButtonThe "Highlight Device" button activates/deactivates the highlight mode for the selected interface and universe.
Select one or more interfaces and press the button. The corresponding fixtures at the selected interface(s) will flash for a better identification. This makes it easier to see them on stage. It considerably speeds up the procedure of programming the selected DMX512/Art-Net interfaces.
DMX Watcher
DMX WatcherWatch UniverseOpen the "DMX Watcher" to monitor your DMX output or input. "Watch Universe" will appear when you have selected a list entry. The DMX Watcher will open with the particular DMX Universe already entered. Learn more in the chapter Tools.
Resizing The Window
Further Configuration
Please keep in mind that network devices, even if activated but not used, cause network traffic!
When using a network-based output protocol and when the start option "Run MADRIX, When Windows Starts" is used, it is highly recommended to also activate the start option "Set Timeout To Start Software" with a value of "30".
