TRI Water
Port Settings
SCE Water displays the rising waves as droplets drop into water when triggered by you.
The lowest input triggers an object to the far left by default. The highest input triggers an object to the far right by default. In-between triggers are assigned to in-between positions.
Port Settings
Port - Selects the Trigger Port [1 - 8].
- Make sure to select the correct port first.
- This setting should correspond to the settings you have made in the Device Manager. Learn more »Configuration Of TRI
BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999.
Energy - Defines how strong the resulting waves are [in %]. The default value is 40. Valid values range from 1 to 20.
Length - Defines the size the waves [in % of the Matrix Size]. The default value is 50. Valid values range from 1 to 200.
Displacement - Defines the amount of distortion. The default value is 0. Valid values range from 0 to 100.
Pitch - Defines the distance between objects for all 3 axes. The default values are 10, 10, 10. Valid values range from 0.01 to 100.
Displacement Distribution - Is only available for Displacement. Is applied in dependence of the direction that is chosen. Allows you to choose the area the distortion is applied to [Uniform, Linear Increasing, Linear Decreasing, Triangle]. The default setting is Uniform.
Displacement Speed - Is only available for Displacement. Allows you to choose to speed in which the distortion affects the visuals. The default setting is 10.0.
Reflection - Lets waves rebound off the four edges.
MADRIX 5.1.
