TRI Color Change
<< Click To Display Table Of Contents >> You Are Here: MADRIX Effects > [TRI] Trigger Effects > TRI Color Change |
TRI Color Change automatically changes colors when triggered by you.
The lowest input triggers the first color in the Color Table. The highest input triggers the last color in the Color Table. In-between trigger inputs are assigned to the in-between colors of the Color Table.
![]() Default Settings |
![]() Customized Example |
Learn more »Effect Options
Port - Selects the Trigger Port [1 - 64]. |
▪Base Color - Is only available when using the mode Flash. Defines the standard color that is shown. The default color is White with Alpha.
▪Fade In - Defines how long a color needs to be fully visible [in s]. The default value is 20. Valid values range from 1 to 100.
▪Fade Out - Defines how long a color needs to disappear again [in s]. The default value is 40. Valid values range from 1 to 100.
Colors - Opens the Color Table to specify the colors. The default colors are Red, Yellow, Green, Cyan, Blue, Magenta. |
Fade - Creates a smooth transition between colors of the Color Table. It is activated by default. |
Automatic - Automatically sustains the trigger port input even if you may already released the control/button in order to fully execute the fade. It is activated by default. If deactivated, the fade will be executed as long as the effect is triggered by pressing the control/button. |
Trigger Mode - Selects the trigger mode. |
| MADRIX 5.7. |
