SCE Water |
SCE Water displays the rising waves when droplets drop into water.
▪This MADRIX Effects supports Effect Options for advanced workflows. Learn more »Effect Options
This MADRIX 5 Effect uses the following, individual controls: ▪Colors - Opens the Color Table to specify the colors. The default color is White. ▪BPM - Defines the speed. The default value is 3000. Valid values range from 0 to 9999. ▪Energy - Defines how strong the resulting waves are [in %]. The default value is 40. Valid values range from 1 to 20. ▪Length - Defines the size the waves [in % of the Matrix Size]. The default value is 50. Valid values range from 1 to 200. ▪Displacement - Defines the amount of distortion. The default value is 0. Valid values range from 0 to 100. ▪Pitch - Defines the distance between objects for all 3 axes. The default values are 10, 10, 10. Valid values range from 0.01 to 100. ▪Interval - Defines the time between droplets [in s]. The default value is 2. Valid values range from 0.01 to 60.
| MADRIX 5.7. |
