SCE Wave / Radial
SCE Wave / Radial
SCE Wave / Radial displays various linear or circular waves.
This MADRIX Effect creates a completely seamless loop.
Effect Options
Learn more »Effect Options
Length - Defines the length of the wave. The default value is 100. Valid values range from 1 to 500.
Width - Defines the width of the wave. The default value is 100. Valid values range from 1 to 500.
Count - Defines the number of extensions for mode Radar and Helix. The default value is 1. Valid values range from 1 to 50.
Factor - Influences how the wave is drawn and bends the wave [in %]. The default value is 0. Valid values range from 0 to 100.
Amplitude - Defines the intensity of Factor. The default value is 50. Valid values range from 0 to 100. Factor needs to be higher than 0 to use Amplitude.
Displacement - Defines the amount of distortion. The default value is 0. Valid values range from 0 to 100.
Center - Defines the position of the center in X, Y, and Z [in %]. The default values are 50, 50, 50. Valid values range from -1000 to 1000.
Peak - Defines the position of the peak of the wave. The default value is 50.00. Valid values range from 0.00 to 100.00.
Displacement Distribution - Is only available for Displacement. Is applied in dependence of the direction that is chosen. Allows you to choose the area the distortion is applied to [Uniform, Linear Increasing, Linear Decreasing, Triangle]. The default setting is Uniform.
Displacement Speed - Is only available for Displacement. Allows you to choose to speed in which the distortion affects the visuals. The default setting is 10.0.
Direction - Allows you to choose the direction of the movement. This includes all directions for 2D and 3D mode. The default setting is Front. Learn more »Using Directions
Mode - Allows you to choose the main mode. This heavily influences the visual outcome of the effect [Linear, Circle, Square, Diamond, Radar, Helix, 3D Sphere, 3D Cube, 3D Octahedron]. The default setting is Circle.
- Make sure to adjust the Direction as required [especially for Mode Linear]!
Draw Mode - Allows you to change the wave form, which influences how the effect is drawn [Sine, Absolute Sine, or Triangle]. The default setting is Sine.
Movement - Allows you to choose the movement direction [Inwards or Outwards]. The default setting is Outwards.
Rotation - Is only available for specific shapes. Allows you to choose the rotation direction [Clockwise or Counter-clockwise]. The default setting is Clockwise.
MADRIX 5.8.
