M2L Shapes |
M2L Shapes displays various objects available in different shapes according to the music.
▪This MADRIX Effects supports Effect Options for advanced workflows. Learn more »Effect Options
This MADRIX 5 Effect uses the following, individual controls: ▪Colors - Opens the Color Table to specify the colors. The default color is White. ▪Fade - Defines how fast MADRIX 5 displays objects [in %]. The default value is 150. Valid values range from 1 to 3000. ▪Size - Defines the size of the objects [in %]. The default value is 10. Valid values range from 0.01 to 100. ▪Pitch - Defines the distance between objects for all 3 axes [in %]. The default value is 10, 10, 10. Valid values range from 0.01 to 100. ▪Border - Defines the size of an object's border [in %]. The default value is 1. Valid values range from 0.01 to 100. ▪Alpha Mix - Defines the upper limit of how much alpha is added to each object. Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100. ▪Sensitivity - Defines how quickly and accurately MADRIX 5 reacts to the music. The default value is 50. Valid values range from 0 to 100. ▪Tone Range - Defines the range of tones analyzed and used by setting a minimum and a maximum value. Narrow the range if your audio signal does not include a wide range of tones to avoid a lot of empty space where no objects are shown. The default values are C1 and C9. Valid values range from C-1 to G9.
MADRIX 5.6. |
