M2L Note Flash |
M2L Note Flash analyzes the music for certain notes and flashes the LED matrix when such notes occur in the music.
▪This MADRIX Effects supports Effect Options for advanced workflows. Learn more »Effect Options
This MADRIX 5 Effect uses the following, individual controls: ▪Color - Defines the color. The default color is White. ▪Fade Out / In - Defines how fast MADRIX 5 flashes [in %]. You can specify the fade-in speed as well as the fade-out speed. The default values are 120 and 3000. Valid values range from 1 to 300. ▪Threshold - Defines a minimum level of the note that must occur before the effect is triggered [in %]. The default value is 50. Valid values range from 1 to 100. ▪Tone - Defines the note at which the effect is triggered. The default value is B1. Valid values range from C-1 to G9. ▪Bandwidth - Defines the lower and upper limits of the analyzed frequency spectrum with Note at the center of the curve [in %]. The default value is 22. Valid values range from 1 to 100.
MADRIX 5.6. |
